Installers & partners
Fronius Symo Advanced is UL 3741 certified with PanelClaw and IronRidge
1/20/2023 / United States
Fronius USA - Portage, Indiana.
The Fronius Symo Advanced inverters are  UL 3741* certified for use with two racking manufacturers, IronRidge and PanelClaw. These solutions are alternative ways to comply with the NEC 690.12 rapid shutdown inside the array boundary requirement.
Fronius Symo Advanced is UL3741 certified with Ironridge and Panelclaw racking systems
Fronius Symo Advanced is UL 3741 certified with PanelClaw and IronRidge racking systems
What does this mean for you?
No module level shut down required! With this certification, module level rapid shutdown devices are no longer required on PV systems when using Fronius Symo Advanced inverters in combination with the following racking systems**:
  • clawFR 5 degree (PanelClaw)
  • clawFR 10 degree (PanelClaw)
  • Dual tilt flat roof (PanelClaw)
  • BX Ballast System (IronRidge)
*The UL 3741 PVHCS* (PV Hazard Control System) is one of two ways to comply to rapid shutdown of PV systems on buildings for the inside of the array boundary. When installing the Fronius Symo Advanced inverters within 1 foot of the array boundary, the inverter becomes part of the array, allowing for compliance with the inside and outside of the array boundary.With the combination of PanelClaw's and IronRidge's wire management solution, you will save time on installation, 3 to 5 cents per watt on CAPEX, and provide a higher reliability for the system due to no longer needing module level shutdown devices.
**You must follow the racking manufacturer's installation instructions for PVHCS System listing found within the racking manufacturers addendum for UL 3741.
Visit the racking manufacturers websites for installation requirements and instructions:
PanelClaw website
IronRidge website
