Being independent of the mains supply
From power failures to voltage fluctuations: with the right charging technology, you no longer have to worry about these difficult situations.
Fronius battery charging systems compensate for power failures
Power failures are always a possibility in production and logistics operations, and in many countries they are even part of day-to-day life. They pose particular challenges for battery charging technology, as the charging process is interrupted and then starts from the beginning as soon as current is flowing again. This reduces the quality of the charge significantly, owing to the fact that the batteries become too hot, leading to a reduction in their service life and capacity. The result is unnecessary costs for new purchases and reduced availability of the entire forklift truck system.
Fronius Selectiva battery charging systems are equipped with an automatic mains failure detection feature. Users can activate this feature - in which the battery charging system automatically detects any interruption in the power supply and stores failures so that they can be analysed using the I-SPoT Viewer software tool - whenever they want. The user can also specify via the display how the battery charging system is to proceed when the power supply is restored, for example by adapting the charging characteristic accordingly. This prevents overcharging whilst increasing the availability and service life of the battery.
Battery charging systems from Fronius compensate for voltage fluctuations
