Everything in view with Charge & Connect
With the cloud-based software solution, you always have the charging data of your forklift truck charging infrastructure in view. Learn more now!
A decisive factor for economic efficiency in intralogistics is ensuring maximum availability of systems and forklift trucks. Downtimes of the forklift truck fleet cause high costs and drastically reduce the own productivity. Digital networking of the charging technology can make an important contribution to increasing the availability of the forklift truck fleet..
With our software solution Charge & Connect, it is possible to digitally link your forklift truck charging stations. A clear dashboard creates transparency with regard to all relevant charging data. Thanks to this continuous monitoring of your chargers, you can reduce downtimes of your forklift truck fleet to a minimum. In addition, application errors can be detected promptly and avoided in the future.
To enable you to react as quickly as possible when problems arise in the charging infrastructure, it is crucial to be alerted to misbehavior at an early stage. Our digital networking solution Charge & Connect sends automated push notifications in the event of anomalies in your charging infrastructure. You receive a detailed error description with associated step-by-step troubleshooting instructions. This means you are alerted to faults at an early stage and maintain an overview - even without being on site yourself.
Above all, extending battery life is an important cost factor for many companies. The uneven utilisation of the individual batteries leads to incomplete charging processes. On the one hand, this reduces the operating time of the forklift trucks and, on the other, leads to losses in battery life and, in turn, to higher costs.
Our proven battery management system "Cool Battery Guide (CBG)" helps you improve the utilisation of your battery pool - and thus extend the service life of your traction batteries. The Cool Battery Guide can now also be used digitally via our Charge & Connect software. It can be easily activated with just a few clicks in the dashboard. Based on the processed signals of the chargers, you now always have the longest fully charged and thus the coolest battery in view. A blue illuminated LED strip on the charger intuitively guides your employees to the battery that is ready for use.
For many industrial companies, load peaks cause high electricity costs, which is why a reduction of these peaks leads directly to cost savings. Digital networking of the charging infrastructure can be used to avoid such load peaks.
Do you know the AC power draw of your charging infrastructure incl. min. and max. value of the last 24 hours? In the Charge & Connect dashboard, this value is visible at a glance. Through the long-term display of the power drawn by the chargers, you can easily see whether and at what times there are expensive load peaks. Based on this data, measures and optimisation steps can be initiated to reduce energy costs.
