Charge & Connect connecting your charging technology
More efficiency, new transparency
Everything at a glance. With Charge & Connect, you can go beyond the limits of conventional charging. The cloud-based software solution connects directly to your charging infrastructure and provides real-time data on its availability and status.
Numerous analysis functions help you detect application errors at an early stage and derive measures to reduce costs and improve performance. Benefit from unprecedented transparency across all charging stations. Increase the performance and efficiency of your intralogistics.
Compelling Advantages for a competitive edge
More transparency and control
With Charge & Connect, you always have a clear overview of your entire charging infrastructure. The data transparency you gain allows you to optimize your charging flows in the best possible way and adapt them individually to your needs.
Reduce your total costs (TCO) sustainably
Combining technologically advanced chargers with our digital connectivity solution, Charge & Connect, helps you reduce your energy costs, increase efficiency and minimize potential risks of downtimes.
Optimized operation
For optimal operation of your charging stations, Charge & Connect provides you with a clear and intuitive overview of your charging data and allows you to identify application errors immediately and avoid them in the future.
CHARGE & CONNECT DASHBOARD The current status of the charging stations at a glance in the Charge & Connect Dashboard.
Availability of the chargers Are any chargers currently in a state of error?
Connected batteries On how many available chargers is a battery currently connected to? How many batteries from the battery pool are currently being charged?
Batteries status How many cooled batteries do you currently have available? How many are fully charged? Which ones have a battery error?
AC Power Do you know the AC power consumption of your charging infrastructure including minimum and maximum values of the last 24 hours? Now these values are available at a glance in the dashboard.
Connected batteries
Batteries status
AC Power
Sustainably increase Performance with Charge & Connect
Man using Charge & Connect to monitor the performance of the charging infrastructure.
Push notifications
In order to be able to react as quickly as possible when problems arise in the charging infrastructure, it is crucial to be alerted to misbehavior at an early stage. Our digital networking solution Charge & Connect sends automated push notifications in the event of abnormalities in the charging infrastructure. This means that faults can be detected at an early stage - even without being on site yourself.
Minimizing downtime
The Charge & Connect dashboard creates transparency with regard to all relevant charging data. Thanks to this continuous monitoring of the chargers, downtimes of the forklift truck fleet can be reduced to a minimum. In addition, application errors can be detected promptly and avoided in the future.
Charge & Connect Features
The setup: industry-safe data transmission in real time
Gateway Charge & Connect
Gateway for data transmission
Each of our Fronius Selectiva 4.0 and SelectION chargers is equipped with its own Gateway and connected via Gateway Link. This enables secure and stable data transmission between the charger and the Gateway without interruption. Depending on your local conditions, you can transfer your charging data via WLAN or LAN. Using the company's own Internet, the data is sent to the Charge & Connect cloud and visualized for you in the Charge & Connect dashboard.
1. Selectiva 4.0 / SelectION
2. Gateway
3. LAN / WIFI connection
4. Switch / Router
5. Client Internet / LTE Router
6. Fronius Charge & Connect
Ready for next level charging? Contact us now!
I am interested in
My contact data
