BlogExperience reportsSupport area
Fronius Wattpilot Flex
Future driven
Smart Solar Charging for Tomorrow’s Drive
For those who are ahead of their time, Fronius offers the perfect combination of elegant design and state-of-the-art technology with the Wattpilot Flex.
Our electric car charger captures every ray of sunlight from your PV system* and charges your electric car optimally for the next day. Intelligent charging modes in combination with a variable electricity tariff enable you to use your self-generated solar power cost-effectively and efficiently and, if necessary, increase the range of your car for the next day with cheap electricity from the grid.
The Fronius Wattpilot Flex is available in a Home and a Pro version, which is ideal for company cars.
*Additional components are required for charging with PV surplus. All details can be found in the operating instructions.
Fronius Wattpilot Flex Home
available from Q2/2025
Fronius Wattpilot Flex Pro
available from Q3/2025
Maximum sun
Your energy, your e-mobility. With the Fronius Wattpilot Flex, you can charge your electric car very economically with self-generated solar power. The PV-optimized wallbox automatically switches between 1 and 3 phases to make the best possible use of the sun's power. From 1.38 to 11 or 22 kW (depending on the version), PV surplus is optimally used. No ray of sunshine is wasted.
Thanks to intelligent charging modes, you always have the choice: Eco Mode gives priority to solar power, while Next Trip Mode ensures that exactly the right amount of energy is charged at the right time for your next trip.
If you have a PV system, Fronius Wattpilot Flex gives you a double benefit: you save on charging and also increase your own consumption - which speeds up the amortization of your PV system.
Pure elegance
Experience a new level of charging your electric car - with the Fronius Wattpilot Flex.
This EV charger will impress you with its modern design and its outstanding functionality. The elegant look and high-quality finish make it a stylish addition to your home.
The Wattpilot Flex received the prestigious German Design Award 2025 for its excellent product design even before its official market launch. For design enthusiasts, the wallbox is even available in a limited first edition with a special logo variant.
The optional pedestal allows for easy and clean installation. It is robust, rust-resistant, and flexible in use. Perfect for one or two wall boxes.
E-car charging station Wattpilot Flex mounted on charging column
User-friendly interface
The Fronius Wattpilot Flex offers a user-friendly interface with intuitive touch buttons and clear menu navigation.
WLAN and LAN interfaces
Integrated WLAN and LAN interfaces allow easy integration into your home network.
Solar.wattpilot App
The Solar.wattpilot app enables conveniently control and monitor the wallbox via smartphone or tablet - anytime, anywhere.
RFID technology
Thanks to RFID technology, you can manage different user profiles and always have full control over all charging processes.
Solar.wattpilot App
RFID technology
Discover the highlights of the electric car charger for your home.
Charging precision
The Fronius Wattpilot Flex Pro is the ideal choice for your electric company car.
Thanks to the integrated, MID*-compliant electricity meter, your company car is being charged efficiently while the exact number of kilowatt hours charged are recorded for transparent billing with your employer.
The Fronius Wattpilot Flex Pro can be seamlessly integrated into existing energy systems and impresses with its modern, elegant design in anthracite that blends perfectly into any living environment.
Additional information for commerical customers & installers
Are you interested in a portable charging solution?
The Fronius Wattpilot Go is the portable charging station for use on the go. Thanks to the CEE plug, you can charge whenever and wherever there is a plug socket available.
Technical data
Data Wattpilot Flex Home Wattpilot Flex Pro
Max. charging power 11/22 kW  11/22 kW
Dimensions (LxWxH)  325 x 195 x 105 mm  325 x 195 x 105 mm
Weight incl. type 2 cable  4.1/54 kg (11/22 kW)  4.1/5.4 kg (11/22 kW)
Charging cable 6m cable with type 2 plug 6m cable with type 2 plug
Cable entry Cable entry from top (only permitted indoors), bottom, rear Cable entry from top (only permitted indoors), bottom, rear
Network connection LAN & WLAN  LAN & WLAN
MID meter Not integrated Integrated
Conformity with calibration law (Mess- und Eichrechtskonform) No Yes
Color Telegrey 4 Anthracite
Use* Indoor & outdoor Indoor & outdoor
