Installers & partners
Fronius Wattpilot FAQ
Basics
The Fronius Wattpilot is the intelligent charging solution for all electric car owners. The Wattpilot is available in the following variants – the fixed-mounted Wattpilot Flex Home for home use, the fixed-mounted Wattpilot Flex Pro for billing-relevant applications, the fixed-mounted Wattpilot Home for home use, and the mobile Wattpilot Go for on the go. Each variant is available in 11 and 22 kW.
The device can be operated via the associated Solar.wattpilot app, which also provides an overview of the charging process. The intelligent plug-and-play charging solution features three different charging modes: Standard, Eco, and Next Trip Mode. Additionally, the Wattpilot is PV-optimized, allowing the car to be charged particularly cost-effectively and sustainably with excess solar energy through automatic 1-/3-phase switching from 1.38 to 22 kW in amperage steps.
For basic charging, all you need to do is connect the Wattpilot to the power supply and plug in your car. You can use the Solar.wattpilot app for special settings (PV optimisation, charging modes, etc.).
You can integrate the Wattpilot into a network using WLAN. If the Wattpilot is outside WLAN range, you can boost the WLAN signal using a repeater, WIFI Access Point or PowerLine adapter.
The warranty term is 2 years.
Yes, you can do that. You can run as many Wattpilots in parallel as you like. Each Wattpilot must be individually integrated into the network. However, PV optimisation only ever works on one device.
No, the Wattpilot communicates with the network via WLAN. It detects and dials into the WLAN network automatically. WLAN will increasingly be provided in car parks as many new cars need WLAN, for example for OTA (over-the-air) software updates.
It is not possible to bill for charging costs directly in the back-end, so there is no way of officially producing an invoice in kWh. However, it is possible to record the power used for charging in kWh and to individually log the time for each RFID chip and charging process. This data can be exported as a CSV file, which would enable the charging time to be invoiced (in minutes).
Wattpilot Flex: Wattpilot Flex, mounting bracket and Type 2 plug holder including screws and dowels, reset card, 2 ID chips, quick guide, strain relief 10 - 15mm and 15-20mm including screws, 2 cable ties, 6 rubber grommets. Optionally, ID chips (10 pieces) and a stand can also be purchased.
Wattpilot Home / Go: Mounting bracket, including screws and dowels, Wattpilot, theft protection, reset card, ID chip, and quick guide. Optionally, a Type 2 cable (5m), ID chips (10 pieces), an additional mounting bracket, and various adapter sets can be purchased.
The Wattpilot is made in Austria.
Wattpilot 2.0 has been developed based on a normative change (IEC 61851-1:2019 and IEC 62752:2016). This standard only concerns the manufacturer. The previous version of Wattpilot 2.0 may still be sold and used.
The Wattpilot 2.0 is produced with a newly designed housing. This ensures a higher IP protection (IP 65 instead of IP 54). The safety plug adapter cable is produced in a shorter length. The WLAN range has also been improved. In line with our sustainability strategy, more components from Europe are used to avoid long transport routes. Furthermore, there are two new versions of the Wattpilot 2.0: the Wattpilot Home 22 J 2.0 and the Wattpilot Go 22 J 2.0 AUS (for Australia). All known software features like PV surplus charging etc. are still available for Wattpilot (1.0) as well as for Wattpilot 2.0.
The two additional strands serve as digital input for future applications and currently have no function.
Installation and start-up
You will need to use the Solar.wattpilot app when starting up the Wattpilot for the first time. The Wattpilot must be connected to the Internet to enable various settings to be made and for remote access.
Yes! There are no additional, recurring checks and therefore no need for any servicing.
The device has a built-in residual current protection module with residual current detection (30 mA AC and 6 mA DC). This means that no upstream type B RCD is required. A separate type A RCD and an automatic circuit breaker must be connected upstream for each Wattpilot.
CEE sockets are designed for continuous loads. However, it is important to ensure correct installation and that the plug contacts are in perfect condition (no soiling or oxidation).
A Fronius inverter with Fronius Smart Meter is required at the feed-in point. The following Fronius inverters are compatible with the Wattpilot: SnapINverter with Datamanager 2.0 and GEN24 as well as IG, IG Plus, IG TL and CL series in combination with a Datamanager 2.0.
The combination with a Fronius Ohmpilot and a Fronius compatible DC-coupled battery is also possible.
The Wattpilot can also be operated with other inverters / energy sources in combination with a Datamanager Box 2.0 and Fronius Smart Meter at the feed-in point. However, no other selfconsumption controls (battery, Power2Heat, etc.) may be implemented in parallel, because the controllers can interfere with each other. The loads in the household are not taken into account in the display in the Solar.wattpilot app.
In this case, the maximum charging current is automatically limited to 16 A.
As soon as a CEE plug is fitted, a maximum connection cable length of 30 cm is stipulated by the governing standards. It is therefore not permitted to fit a CEE plug to the connection cable of the Wattpilot Home. Should you require a CEE plug, please opt for the Wattpilot Go.
Features
You can change the charging mode either using the app or a button on the device.
Next Trip Mode ensures that your vehicle is sufficiently charged for your next trip. Watch the video to learn how to use Next Trip Mode.
The Wattpilot can be reset to factory settings using the RFID Reset Card included in the delivery.
Currently, there is no standard for intelligent charging. Therefore, certain car models may experience limitations in cost-optimized charging. Fronius is attempting to configure the optimal charging behavior for each vehicle.
The following car models are affected:
  • Renault Zoe (minimum charging current 10A)
  • Twingo (minimum charging current 10A)
  • Kia e-Soul
  • Mitsubishi i-MiEV
  • Citroen C-Zero
  • Peugeot iOn
  • VW ID.3 / ID.4 (The charging behavior means that charging must not be interrupted)
As vehicle manufacturers continuously offer new software updates, limitations may have been resolved. You can find the selection of the car model in the Solar.wattpilot app under Settings - Cost Optimization - Car.
No, this is not possible with the Fronius Wattpilot.
All settings can also be made locally by connecting to the Wattpilot's hotspot. This is permanently open and secured with a password. The following functions are not possible without a network connection:
  • Remote app access via the internet
  • Coupling with the PV system (PV-optimized charging)
  • Use of flexible electricity tariffs
  • Dynamic load balancing
  • Software updates
No, it is not possible to do this. However, you can set it to charge to a specific power level in kWh or km, and the electric car will then be charged to this level within a defined time period.
It is possible to combine the Wattpilot with Fronius-compatible DC-coupled battery storage units and the Fronius Ohmpilot. Threshold values can be defined for both the battery (state of charge in %) and the Ohmpilot (temperature in °C). As soon as the threshold values are reached, the current power values of the battery and Ohmpilot are considered as surplus. This means that the presence of a battery or Ohmpilot can also be taken into account within the system. Prioritization of the Wattpilot is possible, plus further prioritization of the Ohmpilot and battery can be carried out in the web interface of the inverter.
In the Solar.wattpilot app, you can activate PV surplus charging and make some advanced settings. We show you how to do this in the video.
With the flexible electricity tariffs Lumina Strom HOURLY and aWattar HOURLY you can charge your vehicle with the Wattpilot cost-optimized. In the video we explain the activation in the Solar.wattpilot app.
The variable electricity tariff can be activated under ‘Settings’ – ‘Cost optimisation’. Depending on the country-specific availability, either specific tariffs or bidding zones can be stored. A bidding zone is a defined geographical area in the energy market in which electricity is traded at the current market price. The additional surcharges of the specific electricity tariff used must be added manually.
Yes, PV optimisation can also be implemented with non-Fronius inverters. However, these must be combined with a Datamanager Box 2.0 and a Fronius Smart Meter at the feed-in point. Apart from that, no further energy management (battery, Power2Heat, etc.) may be implemented at the same time, as the control systems can cause faults. The loads in the household are not included in the display in the Solar.wattpilot app.
It certainly can! You can easily activate and deactivate PV optimisation and variable electricity tariff use in the app. This would enable a user without a PV system to use variable electricity tariffs. Conversely, a user with a PV system can use the charging modes without variable electricity tariff. And, as you’d expect, both options can be used at the same time.
Yes, you can! You can define this setting yourself in the app. This also allows you to define the maximum phase-load imbalance of the Wattpilot.
Yes, PV optimisation can also be implemented with third-party inverters. This must be combined either with a Fronius Smart Meter IP or with a Datamanager Box 2.0 and a Fronius Smart Meter at the feed-in point. In addition, no other self-consumption controls (battery, Power2Heat, etc.) may be implemented in parallel, as the controls can interfere with each other. The consumers in the household are not taken into account in the display in the Solar.wattpilot app.
PV optimisation takes place in individual ampere increments and is provided as standard from type 2.
This means charging increments of approx. 230 W (1-phase) or approx. 690 W (3-phase) are possible. The advantage is that the power range of the photovoltaic system can be used at optimum efficiency (charging power of 1.38 kW - 22 kW). Switching works on vehicles that have a 3-phase or 2-phase on-board charger.
Yes, regular software updates are supplied for the Wattpilot. Providing the Wattpilot is connected to the Internet, installing these updates is very straightforward.
Yes, it can. The ID chip has to be connected separately for each Wattpilot.
The Wattpilot will charge for at least 5 minutes to protect the relays.
It will charge at the set amperage. There is no need to reset the electricity limit values.
Yes, the Wattpilot can be controlled via the interface using the Solar.wattpilot app. This interface is encrypted for security reasons and is not disclosed. Furthermore, the Wattpilot offers OCPP 1.6J as an open interface.
In the Solar.wattpilot app, you can activate PV surplus charging and make some advanced settings for it. In the video we show you how it works.
There is no restriction.
For Dynamic Load Balancing, a Fronius Smart Meter IP or a compatible Fronius inverter with a Fronius Smart Meter or a Datamanager Box 2.0 with a Fronius Smart Meter is required at the feed-in point.
Yes, prioritization is possible. If the same priority is set, prioritization is as follows:
  • Priority 1: Standard mode
  • Priority 2: Next Trip Mode
  • Priority 3: Eco Mode
If the charging mode is the same, the current is divided equally.
Yes, this setting can be activated in the Solar.wattpilot app under ‘Settings’ – ‘Load Balancing’ – ‘Dynamic Load Balancing’. This setting is necessary if the maximum current-carrying capacity of the supply line to the Wattpilot charging boxes is lower than the total current of the Wattpilot charging boxes. This avoids tripping the miniature circuit breaker of the supply line.
Yes, the interface can be used to control the Wattpilot via the Solar.wattpilot app. The interface is encrypted for security reasons and is not publicly accessible.
With the charging timer, charging can be blocked or allowed at certain times. This allows, for example, cheaper electricity tariffs to be used overnight. The charging timer can be activated in the Solar.wattpilot app under "Settings" - "Charging timer". With the additional setting "Allow/block charging + PV surplus", charging (grid & PV surplus) is allowed/blocked during the defined period. However, PV surplus is still charged during the blocked times.
The Wattpilot Flex is equipped with ISO15118 communication hardware, which is a basic requirement for bidirectional charging. However, further requirements are necessary for bidirectional charging:
  1. The electric car must support bidirectional charging. There are already a few vehicles on the market that can charge bidirectionally with a special wallbox. However, this is usually not satisfactory for the end user, as the wallbox may no longer work if the vehicle is changed. The system usually offers an emergency power supply, but not a grid-connected function that allows, for example, the house to be supplied with the vehicle at night.
  2. If energy is fed back from the electric car into the house or even into the grid, the respective requirements of the grid operator must be met. In the case of an AC wallbox, the electric car must support this functionality, which means that an electric car must distinguish between different grid requirements depending on where it is currently connected.
In short, while the Wattpilot Flex is equipped with ISO15118 hardware, it does not yet support bidirectional applications.
Tip: Pay close attention to wallboxes from other manufacturers, as ISO15118 hardware is often mistakenly equated with bidirectional charging!
App
You can download the app from the Google Play Store (Android) and the Apple App Store (iOS).
Yes, this is possible via the Solar.wattpilot app.
English, German, French, Italian, Dutch, Swedish, Spanish, Hungarian and Finnish
In the video we explain the meaning of all parameters in the Details menu of the Solar.wattpilot app.
All information about the amount of electricity charged is displayed in the Solar.wattpilot app.
To be able to assign a new password, the Wattpilot must be reset to factory settings.
Service
The Wattpilot can be reset to factory settings using the RFID reset card included in the scope of delivery and in the Solar.Wattpilot app under Internet / Factory settings.
The installer of the Wattpilot should create a service case for the affected Wattpilot on Fronius Solar.SOS. Please make sure to include the serial number, the invoice of the purchase and a picture of the data plate.
If the Wattpilot Flex is connected to the router via LAN, an internet connection is automatically established. To connect via WLAN, the WLAN password must be entered via the Solar.Wattpilot app.
  • Check the phase switchover setting in the Solar.wattpilot app under Settings/Vehicle.
  • Make sure that your charging cable and the charger in your car support three-phase charging and that the Wattpilot is supplied in three phases.
  • Check in the car's app to see if there are settings that restrict charging to one phase.
Make sure to update your Fronius Solar.wattpilot app to the latest version first.
Update your components to the lastest firmware version. For GEN24 inverters with firmware version 1.14.110-1 or higher, make sure the Solar API is activated in the inverter's user interface under "Communication" - "Solar API". Also make sure your inverter and your Wattpilot are within the same IP network, especially if you are using subnets.
Check your network's wifi signal strength at your Wattpilot. For a stable connection the Fronius Solar.wattpilot app should detect your wifi with at least 50 % strength.
Any alterations or modifications to the device without first obtaining the manufacturer's permission can lead to loss of warranty.
Solar.web
You can add your Wattpilot to your PV system in Solar.web in the tab "Settings" - "Components".
If you have not yet created a PV system in Solar.web, register on www.solarweb.com and add your Wattpilot and paired inverter when creating the new PV system. When adding the Wattpilot to Solar.web we recommend that the Wattpilot currently has internet connection and is paired with the inverter. Nevertheless it is also possible to add an offline Wattpilot to Solar.web, but Wattpilot data will first be shown, when the Wattpilot is online and paired.
Yes, multiple Wattpilots can be added to a PV system in Solar.web.
For Wattpilot data to be displayed in Solar.web, ensure the following:
  • The Wattpilot (as well as your inverter) must be added to your PV system in Solar.web in the tab "Settings" - "Components". If this tab is not visible, please ask your installer to assign you "Owner" or "Supervisor" rights for your PV system.
  • Both the Wattpilot and the paired inverter must be connected to the internet.The Wattpilot requires firmware version 36.0 or higher.
  • You can update your Wattpilot in the Solar.wattpilot app in the tab "Internet".
  • The Wattpilot needs to be paired with your inverter. Go to the tab "Settings" - "Cost Optimization" in the Solar.wattpilot app to pair your Wattpilot with an inverter.
  • If the paired inverter is a GEN24 or Tauro, firmware version 1.123 or higher is required. You can update your inverter in Solar.web in the tab "Settings" - "Components".
If the Wattpilot has no internet connection (e.g. due to weak WLAN), live and history data is not available in Solar.web. History data will not be restored when the Wattpilot reconnects to the internet.
Furthermore, Wattpilot data is only shown if the Wattpilot is paired with an inverter of the same PV system in Solar.web. For example, no data is displayed in Solar.web for periods when the Wattpilot Go is used on the go.
The Wattpilot must be paired with the new inverter in the Solar.wattpilot app in the "Settings" - "Cost optimization" tab. The inverter must be replaced in Solar.web in the "Settings" - "Components" tab. Afterwards, all Wattpilot data will be displayed again in Solar.web.
1. APPLICABILITY
1.1 All deliveries and other services effected by ourselves, Fronius Australia Pty Ltd., (ABN: 65 144 615 896) and all payments made to us, shall be exclusively governed by these Terms of Delivery and Payment. Insofar as applicable provisions may be found to be missing therefrom the law of Australia applies. If any business terms of the Ordering Party’s are at variance with these General Terms of Delivery and Payment, we shall only be bound by such divergent terms if we have expressly recognised the same by letter or by telefax.
2. OFFERS
2.2 We reserve the proprietary rights and copyright to all cost estimates, drawings and other documents. The Ordering Party must ensure that these are neither disclosed to any third party nor used for the purposes of any third party.
Acceptance of an order, and any undertakings or supplementary agreements made by our employees, as well as amendments and alterations of any kind, shall not be binding upon us until we have issued written confirmation by letter, telefax or email.
4.1 Unless otherwise stated, prices are always the net price valid on the date of delivery and they shall apply Ex Works (EXW [Incoterms in the latest version]), but exclusive of packaging, insurance, loading at the factory and GST; packaging is not returnable.
4.4 If the payment period is exceeded, we shall be entitled to charge default interest at a rate of ten percentage points above the applicable base rate announced by the Reserve Bank of Australia, plus the collection costs, such amounts to total at least 12% p.a. of the overall claim or such lesser amount determined by us. This is without prejudice to any further consequences of default in payment.
4.5 The Ordering Party must not withhold payments or offset these against claims we make.
5.1 The delivery period commences with the mailing of the order confirmation note, while the performance period for installation, maintenance or repair work commences when the equipment is handed over. On no account, however, shall the delivery or performance period start to elapse sooner than 14 days after the time when the Ordering Party has furnished us with the documents (e.g. engineering drawings, plans etc), permits or approvals which it is responsible for procuring, or when it has made the agreed pre-payment. The delivery or performance deadline is deemed to have been met if we have notified the Ordering Party prior to such deadline of our readiness to deliver or perform. In cases where a special agreement obliges us to dispatch or deliver by a deadline, the delivery or performance deadline shall be deemed to have been met if the object of delivery or performance has left our factory prior to such deadline.
5.2 Delivery or performance periods are extended for the duration of any unforeseen impediments lying outside our control, such as but not limited to stoppages, major personnel outages, unlawful strikes, delays in supplies of essential raw materials or components or the like, as well as by circumstances where risk is borne by the Ordering Party, to the extent that these impediments and/or circumstances are of material relevance to the failure to meet the deadline. Impediments and/or circumstances of this nature also prevent a default arising for which we would otherwise be liable, for the duration of such impediments and no contractual remedies for which we would otherwise be liable will apply. Immediate notification is to be given by the Ordering Party of the beginning and end of such impediments. We are entitled to terminate the contract, in whole or in part, if such impediments should occur. In this case, to the extent permitted by law, we exclude all liability of any kind whatsoever except to the extent the Ordering Party proves intent and gross negligence on our part.
5.3 If agreed delivery or performance deadlines, or deadlines that have been extended in accordance with 5.2 above, are exceeded by more than four weeks, the Ordering Party shall be entitled to terminate the contract, having granted us at least 14 days’ extra time by notice given to us in a registered letter. In this case, to the extent permitted by law, we exclude all liability of any kind whatsoever except to the extent the Ordering Party proves gross negligence on our part.
5.4 If the Ordering Party incurs a loss from a delay for which we are liable, then it shall be entitled to compensation amounting to 0.5% per whole week - up to a maximum of 5% - of the value of that part of the delivery which cannot be used in time or for its intended purpose as a result of the delay. For other services, the compensation shall be 5% of the remuneration. In this case, we exclude all other liability of any kind whatsoever except to the extent the Ordering Party proves gross negligence on our part. In addition, we are not liable for any delays caused by our suppliers. This clause applies to the extent permitted by law.
5.5 In cases where we have undertaken to effect shipping, the mode and route of shipping shall be for us to decide. Goods are always shipped at the Ordering Party’s risk and expense. To the extent permitted by law, we exclude all liability of any kind whatsoever in relation to shipping except to the extent gross negligence is proven on our part. We shall only take out transport / breakage insurance by order and for the account of the Ordering Party.
5.7 Our compliance with the delivery period shall be contingent upon the Ordering Party having fulfilled its contractual obligations in all pending, still-to-becompleted business transactions.
5.8 If shipping is delayed due to circumstances where risk is borne by the Ordering Party, then this latter shall bear all resulting additional costs, such as those for storage at our factory, but with a minimum monthly charge of 0.5% of the invoice amount. In such a case we shall also be entitled to grant the Ordering Party a grace period of at most 14 days, and if this period should expire to no avail, we shall then be entitled, at our own discretion, either to make alternative arrangements regarding the article(s) to be delivered and to effect delivery to the Ordering Party within a suitably extended period of time, or to terminate the contract and claim damages for breach of contract. In this latter case, we are entitled, without having to furnish any particular proof, to require up to 10% of the remuneration for the intended delivery as indemnification. Where appropriately substantiated, we can also claim compensation for any damage over and above this amount.
5.9 Goods ordered on call, or for production with no shipping instructions, must be taken delivery of within three months. If this time limit elapses unused, then the goods will be treated as subject to a shipping delay due to circumstances where risk is borne by the Ordering Party, and 5.8 shall apply.
5.10 For services performed under contracts for work and materials (4.7), the Ordering Party is to provide us with the necessary equipment and auxiliary materials (e.g. winches, rails, electricity etc.), in good time and at no charge, even if installation is included in the price (4.1) or if a flatrate price has been agreed for this. Any works needing to be carried out by the Ordering Party preparatory to installation, e.g. building work, must be completed prior to the arrival of our installation technicians. Furthermore, the Ordering Party must take all safety precautions needed for the protection of persons and property. To the extent permitted by law, we shall not accept liability for the ancillary personnel, equipment and auxiliary materials which may be placed at our disposal unless gross negligence is proven on our part.
6. PASSAGE OF RISK
6.1 Unless otherwise stated, risk shall pass to the Ordering Party as soon as the articles to be delivered, or the articles on which we have performed maintenance, repair or other work, have left our factory. The same shall also apply to partdeliveries or in cases where we have undertaken to bear the shipping charges or to perform delivery, settingup, assembly, installation or other similar services. If the maintenance, repair or other work is carried out at the premises of the Ordering Party, then risk shall pass to this latter as soon as it has received notification that the work in question has been completed.
7. RETENTION OF TITLE; RESCI
7.1 We shall retain title to the article(s) delivered until the following have been settled in full: our purchase-price claims; and all other claims that we have – on whatever legal grounds – against the Ordering Party. Our legal expenses incurred in connection with the enforcement of our title are to be borne by the Ordering Party.
7.2 The Ordering Party is only permitted to resell the article delivered – even if this has been joined to other items or subjected to processing – in the course of its company’s regular business operations. However, this permission is precluded if the resulting claims are assigned to third parties or are the subject of an assignment prohibition, or if the Ordering Party is insolvent or in default with the performance of its contractual obligations. No other manner of disposition whatever is permitted to the Ordering Party. In the event of distrainment, confiscation or other disposition by third parties, the Ordering Party is to notify us hereof immediately.
7.3 The Ordering Party assigns to us its claims and other rights from the re-sale, rental or leasing of the article delivered, even if this latter has been joined together with other items or subjected to processing; the Ordering Party shall make an entry to this effect in its books. If the article delivered is sold or placed into the hands of a third party for such party’s use together with other items (regardless of whether or not it has been joined to any such items or subjected to processing), then the receivables claim shall only be assigned up to the amount of the purchase price owed to ourselves. This is without prejudice to any further damages claims.
7.5 If the Ordering Party should act contrary to the terms of the contract – in particular by being in arrears with payment or with any other contractual obligation, and/or by being insolvent – we shall be entitled, at our own discretion, either to terminate the contract without granting any grace period or, while leaving the contract in force, to take back the article delivered or to forbid it to be used. We shall also be entitled to sell the taken-back article in the open market; after deduction of a handling fee of 10% of the proceeds thus realised (or such lesser amount determined by us), the remainder will be debited from the total of our outstanding claims against the Ordering Party. In the event of our terminating the contract, we shall charge the Ordering Party a usage fee of 5% of the original value of the article (or such lesser amount determined by us) or the actual diminution in its value if greater.
8. WARRANTY
8.1 Certain legislation, including the Australian Consumer Law, may imply guarantees, warranties or conditions or impose obligations upon ourselves which cannot be excluded, restricted or modified, or cannot be excluded restricted or modified except to a limited extent. These General Terms of Delivery and Payment must be read subject to these statutory provisions.
8.2 We give no warranty for ordinary deviations in size, weight or quality (or as tolerated by ÖNORM, EN or DIN standards or other applicable standards), and also no warranty for information given regarding the suitability of the article(s) to be delivered for the purpose contemplated by the Ordering Party, or for any other particular purpose.
8.3 We warrant the correctness of our processing instructions, user/operating manuals and customer advisory service. We do not warrant compliance with statutory or other regulations when using the articles delivered, and the testing of these articles for the purpose envisaged, shall remain the sole responsibility of the Ordering Party. To the extent permitted by law, we shall only be liable for any instructions differing from our written processing instructions and user/operating manuals if we expressively previously confirmed these deviations to the Ordering Party in writing, either by letter, telefax or e-mail.
8.4 Articles or services supplied must be inspected by the Ordering Party immediately after delivery has been taken of them. Any defects must be reported to us during the warranty period and immediately upon being discovered, in a written notice sent by letter, telefax or e-mail quoting the number and date of the order confirmation note, of the delivery note or of the invoice, and the serial and commission numbers. If the Ordering Party omits to make this immediate notification, it may no longer assert any warranty claims or claims for compensatory damages on account either of the defect itself or of any misapprehension as to whether the delivery or service was free of defects. The notice must set out which delivered items or supplied services are affected by the defects, what the defects consist of in detail, and under what concomitant circumstances these defects occurred. Every single defect must be exactly described. Any costs which we incur as a result of unjustified notices or notices that are otherwise at variance with the conditions of use are to be refunded to us by the Ordering Party. The liability limitations in this clause apply to the extent permitted by law.
8.5 In the case of corrective and preventive maintenance work, our warranty shall be limited to the services actually rendered. We shall only warrant correct functioning of an installation, machine, software or the like whose components were not all supplied by ourselves if we provable have undertaken – despite the provision of certain components by the Ordering Party or by third parties – to manufacture the installation (or machine etc.) as a whole, and if the faulty functioning in question is not attributable to incorrect or incomplete information from the Ordering Party.
8.6 Unless otherwise agreed, the warranty period for all warranted articles or services shall be 24 months. From the beginning of the 13th month of this period, however, our warranty shall be limited to making available, free of charge, the items needed for remedying the defects; from this time onwards, any warranty claims going beyond the above shall not be permitted. This period of limitation also applies to the supply of items deemed to be immovable and to work on items which are, or are deemed to be, immovable. The warranty period shall start to elapse upon the passage of risk (6.). The Ordering Party must always prove that defects coming to light during the warranty period were already present at the time of the passage of risk.
8.7 In cases where we do give warranty, we shall – at our own discretion and within a reasonable period of at least 4 weeks’ duration – either exchange the defective article itself, or its defective components, for a defect-free article or defect free components, or remedy the defect(s), or grant the Ordering Party a reasonable reduction in price, or (unless the defect in question is a minor one) cancel the contract. The warranty period is not prolonged by the exchange of the item or of parts or components belonging to the item. If, however, the remainder of the warranty period – including that part of the period during which our warranty is limited to free provision of the requisite materials (8.5) – lasts for less than twelve months, then the warranty period for the exchanged items, parts or components shall be extended to twelve months. The items, parts or components thus exchanged shall become our property. We shall not refund the costs for any actual or attempted remedying of a defect by the Ordering Party or by any third party.
8.8 To the extent that is necessary and may reasonably be expected of the Ordering Party, the object of delivery or performance, or the defective part(s) thereof, are to be dispatched or shipped to us immediately at our request, at the Ordering Party’s risk and expense, failing which to the extent permitted by law any and all warranty obligation on our part shall become void.
8.9 The Ordering Party is not entitled to withhold payments on account of warranty claims or other counter-claims not recognised by ourselves.
8.10 Warranty claims from the Ordering Party are excluded in cases where the installation, user and operating manuals provided by ourselves, or to be requested from us by the Ordering Party, have not been observed, or where the user has not fully observed such instructions; if the installation work has not been performed properly and in accordance with the relevant Standards, and in particular if the installation work was not carried out by licensed contractors; if any corrective maintenance or other work has been performed on the object of delivery or performance without our consent; if it has been improperly operated or used, or operated despite its protective features being faulty, or taken out of the contract territory without our consent, or used contrary to our instructions or for purposes for which it is not intended; and, moreover, where defects are attributable to foreign object damage, chemical influences, overvoltage, the conduct of third parties or to force majeure; the same applies in respect of natural wear-and-tear.
8.11 Our warranty is also excluded in cases where we have been contracted to carry out repair-orders, to alter or modify used items, or to supply such items.
8.12 Finally all warranty claims shall be excluded if Contractee installs third-party components or replacement parts in our delivery items or services provided by us which have not been expressly recommended by us prior thereto.
8.13 In addition to the rights of Contractee in accordance with Point 8.6 regarding the delivery of inverters for photovoltaic systems the guarantee in accordance with the guarantee conditions of Fronius shall apply, available at https://www.fronius.com/en/photovoltaics/products/all-products/solutions/fronius-service-solutions/fronius-warranties/fronius-warranties
9. DAMAGES
9.1 We shall indemnify the Ordering Party for damage it suffers directly to the extent that the Ordering Party proves that we ourselves brought about this damage either knowingly and willfully or grossly negligently. If the Ordering Party proves that we have caused damage in an ordinarily negligent manner, to the extent permitted by law and subject to clause 9.4, our obligation to indemnify shall be limited to the direct damage actually incurred by the Ordering Party, and, moreover, to a maximum overall amount not exceeding the total order value. Furthermore, to the extent permitted by law, claims of this type may only be enforced if made by the Ordering Party within six months of the damage in question becoming known.
9.2 In the event that a claim is made by a third party, and we have produced and delivered in accordance with the drawings, designs, models or other documents provided by the Ordering Party, the Ordering Party shall indemnify and save us harmless for all loss suffered in connection with that claim.
9.3 To the extent permitted by law, our liability to pay damages for property damage, including all rights of recourse, is excluded. When using the installations, machines and other articles delivered by ourselves, the Ordering Party is obliged to strictly observe all safety regulations, technical rules, installation regulations, operating instructions and user manuals, and in particular all regulations applying to the electrical engineering field, and to allow only authorised skilled personnel to operate the equipment.
9.4 Certain legislation, including the Australian Consumer Law, may imply guarantees, warranties or conditions or impose obligations upon ourselves which cannot be excluded, restricted or modified, or cannot be excluded restricted or modified except to a limited extent. If such legislation applies, to the extent permitted by law, we limit our liability in respect of any claim under such legislation to:
in the case of goods, at our option:
(i) the replacement of the goods or the supply of equivalent goods;
(ii) the repair of the goods;
(iii) the payment of the cost of replacing the goods or of acquiring equivalent goods; or
(iv) the payment of the cost of having the goods repaired.
in the case of services, at our option:
(i) the supplying of the services again; or
(ii) the payment of the cost of having the services supplied again.
9.5 Any liability for damage caused by the installation or use of third-party components or replacement parts with our delivery items, which have not been verifiably and expressly recommended by us, shall be excluded.
Client shall agree that Fronius International GmbH and its subsidiaries may collect, process and use personal data (such as name, address, email address), if applicable also by commissioning a service provider, for the purpose of sending information regarding products and services of any kind (e.g. by post, email, newsletter and more). A dissemination to externals in excess thereof shall not occur (excluded are legal or judicial obligations to provide information). The consent may be objected at any time in writing, in the newslet-ter there is also a link to unsubscribe.
11. FINAL PROVISIONS
Legal disputes arising out of the contract are to be governed by Australian law and the Courts of Victoria shall have non-exclusive jurisdiction. The UN Convention on Contracts for the International Sale of Goods, on the other hand, shall not be applicable.
For software delivered together with other items or for software delivered separately (hereafter “software”) these Terms and Conditions of Delivery and Payment only apply insofar as these do not deviate from the following conditions or from conditions agreed upon separately with Contractee.
12.1 SCOPE OF USE
12.1.1 All rights of intellectual property, such as copyright, trademark rights, design rights, patent rights, utility model rights and know-how, as well as in particular unprotected inventions, commercial experience, trade secrets and such like, independent from the time these were disclosed to Contractee, shall be reserved at any time by us or our licensors. Contractee shall have the right to use the software after payment of the agreed sum exclusively for his own purposes in accordance with the acquired number of licences. With the present contract only the authorization to use the software is acquired. Dissemination by Contractee shall be excluded in accordance with the copyright law. With a possible participation of Contractee in producing the software no rights other than the specified usage laid out in Section 12 are acquired. Contractee may only use the software simultaneously on one device, which one is his decision. Usage of the software shall constitute any long-term or even any temporary duplication (copying) of the software, whether in whole or also only in part, by saving, loading, running or displaying for the purpose of execution of the software and processing of the data contained therein by the hardware. He shall not be authorized to copy the user manual.
12.1.2 Contractee shall be permitted to make copies of the software for archival and data protection purposes on condition that there is no explicit prohibition in the software or any accompanying material (instruction manual, packaging, etc.) and that all copyright and proprietary notices are transferred unchanged in these copies. Retranslations of the programme code (decompilation) exceeding the legal provisions shall not be permitted.
12.1.3. If the software is equipped with technical copy protection, Contractee shall in the case of damage be supplied with a replacement copy after restitution of the data carrier.
12.2 FURTHER RIGHTS
In the event of availability of a new software version Contractee shall be entitled to exchange the supplied software package for a similar software package of the new version at our listed update price; the exchange implies the software package as a whole, as it was acquired by Contractee. With the exchange Contractee’s permission to use the exchanged software package shall expire. In such an event Contractee shall immediately and completely destroy all copies, partial copies and backup copies as well as altered or revised versions of the software and the copies, partial copies and backup copies made thereof.
12.3 WARRANTY
12.3.1 Contractee shall note that it is not possible to develop software programmes in such a manner that these are free from defects for every application condition.
12.3.2 We shall warrant that the supplied software fulfils the agreed functions and has the expressly guaranteed properties. Requirement for any warranty is usage according to contract. A defect for which we are responsible shall only be deemed to exist if the software does not function according to the most recent version of the corresponding performance description/ documentation and if this is reproducible by Contractee. In order to carefully examine possible occurring defects Contractee shall be obliged to support us in the rectification of any defects.
12.3.6 If the software package is not usable or defect (12.3.2), we shall exchange it primarily for a new one of the same title or for an adequate alternative solution. If this also proves to be unusable or defect and if we are not in a position to make it usable with adequate effort within an adequate time, but at least within a period of four weeks, Contractee may demand a price reduction or a change. Costs of defect rectification by Contractee or a third person shall not be compensated by us.
12.3.7 In excess of this (12.3.6) we shall not provide warranty, in particular not in the case of the supplied software not meeting the special requirements of Contractee or user, and also not for altered or revised versions of the software (point 12.1.2), unless Contractee can prove that the defects are not connected to the alterations or revisions. Contractee himself is solely responsible for the selection, installation and usage of the software as well as for the results intended therewith.
12.3.8 In the event of unjustified assertion of defects in the software we shall be entitled to charge Contractee with any incurred costs according to valid cost rates.
12.4 COMPENSATION
12.4.1 All further claims of Contractee or third persons, in particular claims for compensation for damages of any kind, shall be excluded, unless the injured party can prove that the damage was caused by us either intentionally or due to gross negligence.
12.4.2 Otherwise 9 shall apply accordingly.
