Yellow Goods Welding Solutions Highest quality requirements
double productivity
Challenge
Long weld seams, several weld layers and a high deposition rate - at a high welding speeds
Joining heavy components in the Yellow Goods industry represents a particular challenge. Huge components and extremely thick materials are an everyday occurrence – take, for example, a one-and-a-half-meter long heavyduty axle made from steel up to 50 millimeters thick.
The weld seams must withstand high forces and meet stringent quality criteria. The weld seam appearance also plays an important role. Compared to other welding sectors, greater component tolerances and gap-bridging ability are required in the Yellow Goods sector.
Strong partnership for heavy-duty components
A wide range of components of all shapes, sizes, and weight classes require customized welding solutions. The close partnership with Fronius means that an efficient and reliable supply of just such solutions is guaranteed. We are there whenever you need us – quickly, competently, worldwide.
Quality
  • High-quality products that meet every industry standard
  • Outstanding service thanks to highly skilled experts
  • Global support at a local level
Cost-effectiveness
  • Tailored integration of our products in the respective manufacturing process
  • Production costs and cycle times for further developments are always in mind
  • Immediate availability of replacement devices and spare parts in the event of downtime
Know-how
  • Latest developments from the welding sector
  • Professional training for your employees
  • Comprehensive knowledge of production processes in the Yellow Goods industry
Good relationships
  • Long-standing partnerships and reliable collaboration with customers
  • Reliable contact partner and provision of intensive support for all welding matters
Questions on welding solutions for the yellow goods industry?
Excavator
Overlay welding
Challenges
  • High deposition rate
  • Robust equipment
Solution
TPS 600i single wire
  • Welding speed: 60 cm/min
  • Deposition rate: 8 kg/h
Circumferential weld
Challenges
  • Deep penetration
  • Low heat input
  • Little welding spatter
Solution
TPS TWIN CMT
  • Material thickness: 10 mm
  • Deposition rate: 12 kg/h
Fillet weld
Challenges
  • Welding speed
  • Low-spatter
Solution
  • Welding speed: 25 cm/min
  • Deposition rate: 11 kg/h
Fillet weld
Challenges
  • Deposition rate
  • Welding speed
  • Gap-bridging ability
Solution
TPS/i TWIN Push
  • Material thickness: 15 mm
  • Deposition rate: 18 kg/h
Butt weld
Challenges
  • Deep penetration
  • Single-pass welding
Solution
TPS/i TWIN Push
  • Deposition rate: 20 kg/h
Challenges
  • Stable ignition
  • Robust welding torch
  • Interval welding
Solution
TransSteel 3500
High-quality weld seams are absolutely essential when manufacturing components for excavators. Enormous forces act on the individual components such as the frame, boom, or bucket. Perfect weld seams are an important safety criterion.
Telescopic Handler
Fillet weld
Challenges
  • High welding speed
  • Low heat input
Solution
TPS TWIN CMT
  • Material thickness: 8 mm
  • Welding speed: 150 cm/min
  • Deposition rate: 13 kg/h
Butt weld
Challenges
  • Horizontal position
  • Single-layer welding
  • No backing
Solution
LaserHybrid
  • Material thickness: 6 mm
  • Welding speed: 180 cm/min
  • Deposition rate: 4 kg/h
Challenges
  • Low-spatter
  • High-quality weld seam appearance
  • Excellent gap-bridging ability
Solution
TPS/i TWIN Push
  • Welding speed: 100 cm/min
  • Deposition rate: 22 kg/h
Fillet weld
Challenges
  • Stable ignition
  • Robust equipment
Solution
TransSteel 5000
Root pass
Challenges
  • Optimum weld seam quality
  • No pores
  • Start-stop overlap
  • Root pass
Solution
ArcTig
  • Material thickness: 10 mm / 5 mm root face
Telescopic handlers are predominantly used in the construction and agricultural industry. Depending on the design, the construction machine must be able to bear loads of up to 30,000 kg. The weld seams must also be able to withstand this weight, which is why the quality of the welded joints is of utmost importance.
Let´s get connected!
Construction machinery is made from up to 90 percent steel: Fronius welding systems are ideally suited to steel construction requirements. In the field of manual welding in particular, devices in the TPS/i Steel Edition or TransSteel series offer the ideal solution for all steel applications. Special characteristics packages increase productivity and enable reproducible welding results. More about steel welding
System solutions for manual welding
» The TPS/i “Steel Edition” stands for welding without compromise – combined with all the advantages of an intelligent welding system platform. «
» Welding systems in the TransSteel series are completely tailored to the requirements of steel welding and boast: «
Accessories
Exento fume extraction torch
Exento fume extraction torches are the perfect complement to Exento HighVac systems. They meet the requirements of standard DIN EN ISO 21904-1 Health and safety in welding and allied processes.
To the Exento fume extraction torch
Dust filter
The dust filter offers addition protection against contaminants in the housing of the TPS/i – particularly in tough environmental conditions.
Find out more about welding safety
JobMaster
The JobMaster welding torch means that the user always has the most important welding parameters (U, I, Vd) on the torch and can easily switch between them at any time.
To the MIG/MAG welding torches
Production Monitoring with WeldCube.
Global sales and service network
Fronius offers tailored services to customers around the world. We can advise you on our systems in advance and perform welding trials. Our service network makes us a reliable partner, including for aftersales support – we currently have 87 sales and service teams worldwide.
For our customers, this means:
  • Proximity to market
  • Quick response times
  • Expert support from local contacts
Let´s get connected.
