TPS/i Robotics Efficient and accurate
Robotic welding: Where innovation and outstanding performance come together
We combine a culture of innovation and customer focus in a unique way:
since the 1990s, we have been revolutionizing the industry with pioneering solutions for robot-assisted welding.
By making good things even better, we not only develop welding systems, but also create solutions that expand the possibilities of automated robotic welding. We achieve a high quality weld thanks to intelligent control and a stable arc.
Software solutions allowing easy integration plus welding data recording and analysis complete our systems.
The advantages for you
Transformation for maximum efficiency
Converting a manual welding machine to a robotic welding system is quick and easy. All common standard interfaces are available.
Overview of production
WeldCube is a central tool that networks and monitors all welding machines in production, so you can fulfill any documentation requirements. Plus, the component-related evaluation of process data allows you to optimize your production line and realize its full potential.
Easy upgrades
The system’s functionality can be quickly expanded using software options and welding packages.
Ready for use in no time
The TPS/i facilitates quick and straightforward communication with robots from different manufacturers, ensuring rapid integration of the welding system.
Multipurpose for any application
Our welding system is versatile. No matter whether you’re working with aluminum, CrNi, or steel, the TPS/i ensures optimum welded joints. With our solutions, you remain flexible and fully equipped for future challenges. The result: perfect welds with excellent support.
System solutions The TPS/i is one of the most state-of-the-art welding machines and, with its huge power capacity of up to 600 A, it meets the highest demands for steel, stainless steel, and aluminum applications. The modular design of the device platform enables optimal integration into various robotic welding systems. The structure of the system means that custom adaptations can be made, including both Push and PushPull systems.
TPS/i Push systems The system is primarily used in applications with CrNi and steel, where consistent quality and high system availability are crucial. It also features low maintenance and quick assembly.
Wirefeeder Can be expanded with up to two wirefeeders to increase the wirefeed distance
Welding packages Standard, Pulse, LSC, PMC welding processes possible
Welding torches Use of gas-cooled or water-cooled welding torches possible
Magnetic CrashBox The CrashBox minimizes the load on the torch body in the event of a collision and prevents damage. The high reset accuracy (+/- 0.05 mm) allows production to be quickly resumed.
CrashBox
5
From manual to robotics Conversion to a robotic welding machine is quick and easy using a robot interface that enables communication with the TPS/i. All common standard interfaces are available.
Interface
6
TPS/i Push systems
Wirefeeder
Welding packages
Welding torches
5
Magnetic CrashBox
CrashBox
6
Interface
TPS/i PushPull systems These robotic welding systems ensure high process stability, especially for long wirefeeding distances and applications with aluminum alloys or CuSi.
WF 60i Robacta Drive CMT This highly dynamic wirefeeder supports all welding processes, from Standard to CMT. It can be used for both hollow-arm robots and conventional robots.
Touchscreen
Wirefeeder The wide range allows for individual positioning of the wire drum
Welding packages All welding processes possible: Standard, LSC, Pulse, PMC, CMT
Interface
5
Touchscreen
Wirefeeder
Welding packages
5
Interface
100% compatible with our welding packages
Thanks to our modular welding packages, custom solutions can be developed quickly and efficiently. The TPS/i can be flexibly adapted to meet specific welding requirements. The standard or pulse processes are available as basic packages, or advanced welding packages such as LSC, PMC, or CMT can be used for particularly demanding welding tasks. The optimum interaction of welding processes with intelligent penetration and arc length stabilizers makes production faster and of higher quality, which reduces rejected welds to a minimum.
CMT, the stable arc with reversing wire motion
Cold Metal Transfer: The highly specific type of droplet detachment minimizes heat input. Reversing wire motion also ensures low spattering.
Read more about CMT
The optimized PMC pulsed arc
With its optimized pulse characteristics, Pulse Multi Control provides high-quality welds at high welding speeds.
Read more about PMC
The modified LSC dip transfer arc
Low Spatter Control: Soft reignition represents a significant difference compared to the standard dip transfer arc. Here, the short circuit is triggered at a low current level.
Read more about LCS
Faster, more accurate welding with assistance systems
One particularly important factor in robotic welding is increasing the efficiency and quality of welding tasks. Our assistance systems such as TeachMode, TouchSense, WireSense, and SeamTracking further optimize the welding process by saving time, preventing collisions, compensating for tolerances, and increasing process reliability.
WireSense
Reduces time-consuming rework. The wire electrodes measure component deviations such as varying air gaps or clamping tolerances and transmit the values to the robot. More about WireSense
TeachMode
For the efficient programming of welding positions on the robot. The wire is retracted before a collision can occur with the component, preventing the wire from bending. The set stickout remains unchanged. More about TeachMode
TouchSense
Developed for welding fillet welds and prepared butt welds. The wire or gas nozzle scans the component in detail and transmits the start and end position to the robot, which calculates the exact seam path.
ShortCircuitDetection
The welding system detects accumulations of welding spatter inside the gas nozzle. Cleaning routines can be optimized and process reliability increased.
SlagHammer
Start welding safely and cleanly. Before welding starts, slag that has formed on previous welds is chipped away by reversing wire movements.
SFI – spatter-free ignition
The spatter-free ignition with SFI ensures both safe and clean ignition.
TPS/i TWIN—full speed ahead to the perfect result
Consistently high welding speeds with reliable penetration and deposition rates of up to 25 kg/h—that’s what you can expect from our TPS/i TWIN systems.
Read more about TPS/i TWIN systems
Software solutions for TPS/i Robotics
WeldCube Premium
Alongside productivity and time savings, transparency and safety are also common requirements in welding production. The recording of welding data for documentation and analysis purposes can be of invaluable assistance, and is precisely where the WeldCube welding data management software comes to the fore. The premium version provides you with a convenient, centrally located data documentation resource with intelligent management, statistical, and analysis functions, including graphical evaluations. Go to WeldCube Premium
Central User Management
Central User Management enables quick and easy user administration, replacing a separate set-up directly on each device and thus saving a lot of time. It then becomes a simple matter to automatically transfer user rights to new devices. Go to Central User Management
WeldConnect app
WeldConnect makes it easy for welders to find the right parameters for their manual welding task. The app helps determine the correct settings at every step and allows the stored welding parameters to be transmitted wirelessly to the connected welding machine. It can also be used to scan the part, series, and weld numbers for component-specific data documentation and perform user identification with NFC-enabled cellphones. Go to WeldConnect app
SmartManager
SmartManager is a web-based solution that allows you to access TPS/i data documentation from a web browser. The data is recorded locally on the device and made available via WeldCube Light and Basic. All settings can be made on the PC and, if necessary, exported or imported.
API
Our API is an interface solution that enables data to be exchanged with other systems. This means that you can easily access the data on our welding systems and create detailed analyses, evaluations, and visualizations using your own software packages. TPS/i supports the OPC-UA and MQTT protocols and is able to supply live data. Go to API
Let´s get connected.
    1. APPLICABILITY
    2. PRICES AND PAYMENTS
    5. GENERAL EXPRESS WARRANTIES
    5.1 General. Seller warrants to Buyer only, subject to the disclaimers and limitations of the Agreement, that Goods to the extent manufactured by Seller shall be free from defects in materials and workmanship at the time of delivery which are discovered and reported to Seller within the period of 24 months from the delivery date. From the beginning of the 13th month of this period, however, Seller’s warranty shall be limited to making available, free of charge, the items needed for remedying the defects; from this time onwards, any warranty claims going beyond the above shall be inadmissible. This period limitation also applies to the supply of items deemed to be immovable and to work on items which are, or are deemed to be, immovable. The warranty period shall start to elapse upon the passage of risk. Buyer must always prove that defects coming to light during the warranty period were already present at the time of the passage of risk. This is not a warranty of performance, but a limited warranty as to the condition of the Goods at delivery. Seller does not warrant any portion of the Goods not designed, developed or manufactured by Seller (whether or not specified by Buyer), but Seller shall assign to Buyer upon request all assignable warranties of Seller’s suppliers related to such Goods. Because the Goods may be subject to a wide variety of use, installation, maintenance, cleaning, and other factors, the warranty is only against the named defects and not against any other defects or failures such as, but not limited to, those due to normal wear and tear, normal maintenance and unknown causes. Perishable and wear items are excluded from warranty against defects. Buyer shall ensure that all computer equipment and software included with or used with the Goods has adequate protection against viruses or other malicious software after initial installation. Seller’s warranty does not cover damage or contamination caused by such malicious software. Notwithstanding anything to the contrary, there is no warranty as to prototype Goods.
    6. PATENT WARRANTIES
    7.4 Warranty
    9.1 General Remedies. Defective or non-conforming Goods or parts thereof discovered and reported during the express warranty period shall be repaired, or replaced by Seller without any additional charge, and shipped to Buyer, FOB Seller’s plant, for reinstallation by Buyer at its cost, subject to the terms hereof of the Agreement, as Buyer’s exclusive remedy. The warranty obligation of Seller is limited to the repair or replacement at Seller’s plant of any part of the Goods which Buyer shall, within the warranty period, return to Seller, with transportation charges prepaid by Buyer, and which Seller shall determine upon examination to be defective or not in conformity with the express warranties contained herein. Goods cannot be deemed defective or non-conforming if Seller cannot duplicate the alleged failure. In lieu of repair or replacement, if Seller elects, Seller may, upon return of such Goods and making a determination of nonconformity or defect, keep the Goods and refund the purchase price as Buyer’s exclusive remedy. Seller may provide such repairs itself or through its third party contractors. Buyer’s remedies shall be limited (even in the event of Seller’s default of its warranty obligations or a failure of an item to meet its intended purpose) exclusively to those provided in this Section. UNDER NO CIRCUMSTANCES SHALL SELLER BE LIABLE, REGARDLESS AS TO WHETHER SELLER’S LIABILITY ARISES UNDER CONTRACT, TORT, STRICT LIABILITY STATUTES, OR OTHERWISE, FOR EXEMPLARY, PUNITIVE, SPECIAL, CONSEQUENTIAL OR INCIDENTAL DAMAGES, INCLUDING BUT NOT LIMITED TO: LOSS PROFITS OR REVENUES; INCREASED COSTS; DAMAGE TO EQUIPMENT, TOOLING,PREMISES, OR WORK-IN-PROCESS; COST OF CAPITAL; COST OF PURCHASED POWER; SUBSTITUTE OR ADDITIONAL EQUIPMENT, FACILITIES OR SERVICES; COST OF PRODUCTION INTERRUPTION OR START-UP; OR THE CLAIMS OF THIRD PARTIES FOR SUCH DAMAGES, WHETHER OR NOT THE DAMAGES WERE FORESEEABLE OR SELLER WAS ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. Each provision of the Agreement which provides for a limitation of liability, disclaimer of warranties, or exclusion or limitation of damages or remedy is severable and independent of each other and to be enforced as such. Buyer waives any causes of action or theories of liability relating to or arising under the Agreement including, but not limited to, those arising under contract, tort, strict liability, product liability statutes, or otherwise, except as specifically provided by the UCC as modified and limited herein. The replacement or repair of Goods by Seller does not give rise to any new or extended warranty, and the warranty period provided for herein shall not be extended by the length of any period from the date the defective or non-conforming Goods are received by Seller until the date the repaired or replacement Goods are delivered to Buyer or otherwise.
    10.1 SELLER DISCLAIMS ALL IMPLIED WARRANTIES AND SIMILAR OBLIGATIONS (OTHER THAN THAT THE GOODS WILL BE NEW AND GOOD TITLE) INCLUDING BUT NOT LIMITED TO THOSE OF NON-INFRINGEMENT, FITNESS FOR A PARTICULAR PURPOSE, AND MERCHANTABILITY, WHETHER OTHERWISE ARISING BY LAW, CUSTOM, USAGE, TRADE PRACTICE, COURSE OF DEALING, OR COURSE OF PERFORMANCE. There are no warranties which extend beyond those express warranties contained in the Agreement. Buyer affirms that it has not relied upon Seller’s skill nor judgment to select or furnish the Goods for any particular purpose beyond the specific express warranties in the Agreement. Any design provided by Seller is based on information provided by Buyer. Seller may rely entirely on information provided by Buyer and is under no obligation to verify such information or take any action to obtain explanatory or supplemental information from Buyer or third parties. Buyer’s approval of drawings and/or prototypes constitutes Buyer’s acceptance and waiver of any responsibility for a failure to consider or correct information or approval provided by Buyer. Any modifications of drawings, prototypes and other work of Seller after approval by Buyer shall be at Buyer’s expense at Seller’s normal rates for services and materials. Seller does not warrant the Goods will comply with the requirements of any safety or environmental code or regulation of any federal, state, municipality or other jurisdiction beyond the specific express warranties in the Agreement. Seller does not warrant that the Goods will operate with any accessories or within any system not sold under the Agreement and Seller’s warranty is limited to the operation of the Goods in a stand-alone mode, unless specifically stated in Seller’s written specifications. Some countries, states, or provinces do not allow the exclusion or limitation of implied warranties or the limitation of incidental or consequential damages for certain products supplied to consumers, or the limitation of liability for personal injury, so such limitations and exclusions may be limited in their application to an end user and others. When the implied warranties are not allowed to be excluded in their entirety, they will be limited to the duration of the applicable written warranty. The warranty gives specific legal rights which may vary depending on local law.
    11. INDEMNIFICATION
    12. SECURITY INTEREST
    12.1 In addition to any security interest granted by the UCC or other law, Buyer hereby grants a security interest to Seller in all Goods and documents related thereto and proceeds and products therefrom to secure all obligations of Buyer to Seller, whether or not arising under the Agreement. Seller may file a financing statement and at Seller’s request, Buyer shall sign financing statements and other documents, which evidence perfect and confirm the security interest. Buyer grants Seller an irrevocable power of attorney to sign Buyer’s name to a financing statement or other similar documents if necessary or convenient to perfect Seller’s security interest. Buyer shall not change the name of Buyer, the jurisdiction of Buyer’s formation, or the location of any Goods from the original delivery point or installation site without prior written notice to Seller. Buyer shall provide a lien waiver or subordination from all third parties to whom the Goods may be delivered. Buyer shall provide a landlord’s waiver or subordination of any lien rights at the premises to which the Goods are to be installed. In case of a default by Buyer, Seller may peaceably enter the premises of Buyer and others and take other actions to repossess or render inoperable all Goods in which it has a security interest provided that Seller provides Buyer with immediate notice it has rendered the Goods inoperable. In case of a default by Buyer, Buyer hereby irrevocably appoints Seller as its agent to obtain possession of the Goods and documents related thereto. Seller may install and activate procedures or devices to make the Goods or Software non-operative upon Buyer’s default. The Goods shall be and remain strictly personal property whether or not affixed or attached on permanent foundation or affixed or attached to building or structure. Title shall not transfer to Buyer until the Goods shall be paid in full. Buyer shall maintain the Goods which constitute inventory in a segregated area and not comingle any Goods which are not fully paid. Buyer shall not sell, exchange, transfer, convey, mortgage, pledge, hypothecate or grant a security interest in any Goods which are subject to the Agreement until payment has been made in full to Seller, at which time title shall transfer to Buyer. Buyer shall immediately advise Seller in writing of any damage to, change in location of, or seizure of, any of the Goods the price of which has not been paid to Seller.
    13. PROPRIETARY INFORMATION
    13.2 Seller’s Rights to Confidentiality. All proposals, plans and other information furnished by Seller in bidding, negotiating and performing the Agreement, are confidential and the property of Seller, whether or not marked “Confidential”, and shall not be shown or disclosed to any other bidder, and shall not be shown or disclosed to any other third party or used by buyer unless necessary for the selection or use of the Goods and notice of such disclosure has been given to Seller. Buyer shall treat as confidential any quotation or other business proposal from Seller and all technology which shall be made available, directly or indirectly to Buyer by Seller and by Seller’s licensors, including but not limited to drawings, schematics, specifications, bills of material, test results, analysis, recommendations, models, and designs, and Buyer shall use such proposal and technology only to evaluate its business relationship with Seller and to enable Buyer to perform under the Agreement. Buyer shall not manufacture or sell any product using confidential information provided by Seller or obtained from reverse engineering or decompiling Goods of Seller. Buyer shall not disclose, or authorize or instruct any third party to disclose, any confidential or proprietary information of Seller to any third party that is not bound by contract to at least the same duty of confidentiality to Seller as is Buyer. In addition, only those employees and contractors of Buyer having a need-to-know and bound by contract by the same confidentiality provisions as Buyer may be given access to such technology. Buyer shall maintain, for Seller’s inspection, written records which shall include the names and address of such employees and contractors granted such access. Buyer shall indemnify Seller from all expenses and damages related to the improper use or disclosure by Buyer or its employees and contractors. Business proposals and technology of Seller may be protected by patent, copyright, trademark and other law. No license or other right to business proposals or technology is granted to Buyer except as specifically provided in the Agreement.
    14. BREACH
    15.1 Disclaimer. BUYER AND THIRD PARTIES SHALL NOT BE ENTITLED TO ANY CONSEQUENTIAL, PUNITIVE, LIQUIDATED, EXEMPLARY OR INCIDENTAL DAMAGES, AS DEFINED IN THE APPLICABLE LAW OR OTHERWISE, EXCEPT AS TO ANY INDEMNIFICATION OBLIGATIONS TO THIRD PARTIES SPECIFICALLY PROVIDED IN THIS AGREEMENT. “CONSEQUENTIAL DAMAGES” SHALL INCLUDE, BUT NOT BE LIMITED TO, LOSS OF PROFITS OR REVENUE, LOSS OF USE OF CONTRACT GOODS, COSTS OF REPLACEMENT POWER OR CONTRACT GOODS, ADDITIONAL EXPENSES INCURRED IN THE USE OF CONTRACT GOODS OR FACILITIES, OR THE CLAIMS OF THIRD PARTIES, EVEN IF SELLER HAS BEEN ADVISED OF POSSIBILITY OF SUCH DAMAGES OR IF THEY ARE OTHERWISE REASONABLY FORESEEABLE. THIS DISCLAIMER SHALL APPLY TO INCIDENTAL, CONSEQUENTIAL AND LIQUIDATED DAMAGES BASED UPON ANY CAUSE OF ACTION WHATSOEVER ASSERTED AGAINST SELLER, INCLUDING ONE ARISING OUT OF PRINCIPLES OF CONTRACT, ANY BREACH OF WARRANTY, EXPRESSED OR IMPLIED, GUARANTEE, EQUIPMENT OR OTHER CONTRACT GOODS LIABILITY, NEGLIGENCE, TORT, OR ANY OTHER CAUSE PERTAINING TO PERFORMANCE OR NON-PERFORMANCE TO THE PROPOSAL OR ORDER BY SELLER. This limitation shall be enforced regardless of whether Seller has defaulted in its warranty or other obligations or the limited warranty is held to fail of its essential purpose. Any legal inability to limit or restrict the right of Buyer or a third party to such damages shall not affect the right of Seller to indemnification here-under, and under no circumstance shall Buyer recover more than the purchase price. 15.2 Overall Limitation. IRREGARDLESS OF THE DISCLAIMER IN SUBSECTION 15.1 ABOVE, UNDER NO CIRCUMSTANCES SHALL SELLER’S LIABILITY FOR CLAIMS FOR NON-DELIVERY OR OTHER NON-PERFORMANCE, DEFECTIVE PERFORMANCE, NON-CONFORMING GOODS, DEFECTIVE GOODS OR OTHERWISE EXCEED THE AMOUNT RECEIVED OR TO BE RECEIVED BY SELLER FOR THE PERFORMANCE OR SHIPMENT WHICH CONTAINED THE NON-CONFORMING GOODS, DEFECTIVE GOODS OR SUCH OTHER EVENT GIVING RISE TO THE CLAIM, EXCEPT AS MAY BE SPECIFICALLY PROVIDED BY THESE GENERAL TERMS.
    16. TERMINATION
    17. SEVERABILITY
    18. ASSIGNMENT
