Installers & partners
Fronius Primo GEN24 Plus
Inverter for private PV systems with PV Point or Full Backup
Our single-phase Fronius GEN24 Plus hybrid inverter is the ideal core for private PV systems. The Fronius GEN24 Plus offers an integrated basic backup power supply with PV Point and even a full backup power solution through the option of connecting a battery storage system.
The Fronius GEN24 Plus hybrid inverter enables energy self-sufficiency for electricity, heating, cooling and e-mobility with the use of a battery system. This means that the Fronius GEN24 Plus with Full Backup* has a backup power solutionthat even large consumers can use, such as heat pumps. What’s more, the Multi Flow Technology lets the hybrid inverter supply parallel energy flows in the system, even in backup power mode.
* Additional external components for grid switchover are required for the Full Backup. More information on this can be found in the operating instructions.
Product details
Input Data
Number of MPP trackers2
Maximum PV input power8260 W
Max. input current (Idc max)
22 / 22 A
41,25 / 36 A
65 - 600 V
80 V
Nominal input voltage (Udc,r)
400 V
260 - 480 V
Usable MPP voltage range65 - 480 V
Number of DC connections2+2
12 kWpeak
Output Data
AC nominal output (Pac,r)
8000 W
Max. output power (Pac max)
8000 VA
Max. AC output current45,45 A
Grid connection (Uac,r)
1~ NPE 220/230 V
155 - 270 V
Frequency (fr)
50 / 60 Hz
Frequency range (fmin - fmax)
45 - 65 Hz
Total harmonic distortion<3% @Pnom (230/400VAC 50Hz)
Power factor (cos φac,r)
0,8 - 1 ind./cap.
Output Data PV Point
Nom. output current (Iac max)
13 A
Max. switchover time PV-Point20 s
Battery Connection
Max. input current (Idc max.)
22 A
150 V - 455 V 7)
Max. input / output power (Depending on the connected battery)8260 W
Min. DC input voltage150 V
Max. DC input voltage455 V
General Data
Length595 mm
Dimension / width529 mm
Dimension / height595 mm
Dimension / depth180 mm
Weight21 kg
Weight incl. packaging26,05 kg
Degree of protectionIP66
Protection class1
2 / 3
Night-time consumption9 W
Inverter designTransfomerless
CoolingRegulated air cooling
Ambient temperature range-40°C - +60°C
Permitted humidity0 - 100 %
Max. altitude 2)
4000 m
DC PV connection technology4x DC+ and 4x DC- push-in spring terminals 2.5 - 10 mm²
DC battery connection technology1x BATT+ and 1x BATT- push-in spring terminals 2.5 - 10 mm²
AC connection technology3 pole AC push-in spring terminals 2.5 - 10 mm²
3 pole backup power push-in spring terminals 1.5mm² - 10mm²
2x PE-screw terminals 2.5 - 16 mm² and  3x 2,5 - 10mm²
Back-up power functionsPV Point, Full backup 4)
Compatible batteries 6)
BYD Battery-Box Premium HVS/HVM & LG RESU FLEX 5)
Sound emissions51 dB(A)
Interference emission classB
Efficiency
Max. efficiency (PV - grid)97,3 %
European efficiency (ηEU)96.5 / 96.9 / 96.4 (260Vdc / 400Vdc / 480Vdc)
η at 5% Pac,r 3)
90.3 / 91.2 / 88.7 (260Vdc / 400Vdc / 480Vdc)
η at 10% Pac,r 3)
94.4 / 94.9 / 93.5 (260Vdc / 400Vdc / 480Vdc)
η at 20% Pac,r 3)
96.3 / 96.6 / 96.0 (260Vdc / 400Vdc / 480Vdc)
η at 25% Pac,r 3)
96.6 / 96.9 / 96.4 (260Vdc / 400Vdc / 480Vdc)
η at 30% Pac,r 3)
96.8 / 97.1 / 96.7 (260Vdc / 400Vdc / 480Vdc)
η at 50% Pac,r 3)
97.0 / 97.3 / 97.0 (260Vdc / 400Vdc / 480Vdc)
η at 75% Pac,r 3)
97.0 / 97.3 / 97.1 (260Vdc / 400Vdc / 480Vdc)
η at 100% Pac,r 3)
96.8 / 97.2 / 96.9 (260Vdc / 400Vdc / 480Vdc)
MPP adaptation efficiency99,74
Protection Devices
DC insulation measurementYes
Overload behaviourOperating point shift. Power limitation
DC disconnectorYes
Interfaces
Emergency stop (WSD)Yes
2x RS485Modbus RTU SunSpec (third-party supplier) / Fronius Smart Meter, battery, Fronius Ohmpilot
Integrated data communication
SuperFlex Design
Dynamic Peak Manager
full backup
PV Point
Active Cooling
