Installers & partners
Fronius Symo Advanced UL
SPECIALLY DEVELOPED FOR THE REQUIREMENTS OF TOMORROW
Featuring models ranging from 10 kW to 24 kW, the Fronius Symo Advanced is the ideal inverter for commercial applications. The new Advanced versions combine the benefits of the Fronius Symo with additional features zero tilt mounting, light weight and field serviceability.
Product details
Input Data
Number of MPP trackers2
Max. usable input current41,5 A
Max. array short circuit current (1.5 * Imax)62,2 A
Nominal input voltage
350 V
200-600 V
MPP Voltage Range
300-500 V
Max. input voltage (Udc max)
600 V
Output Data
Max. output power 480 VNA
Max. output power 277 VNA
Max. output power 240 V12 kW
Max. output power 208 V12 kW
Output configuration
3~ NPE 208-240 V
Frequency range50-66 Hz
Frequency60 Hz
Power factor range
0-1 ind./cap.
Max continuous output current 480 VNA
Max. continuous output current 277 VNA
Max. continuous output current 240 V28,9 A
Max. continuous output current 208 V33,3 A
General Data
Dimension / width511 mm
Dimension / height724 mm
Dimension / depth228 mm
Weight43,4 kg
InstallationIndoor and outdoor installation, tilt from 0-90 degrees (Fronius Shade Cover required for installation angles less than 15 degrees)
Permitted humidity0-100 % (non-condensing)
Degree of protectionNEMA 4X
Night-time consumption<1 W
CoolingVariable speed fan
Ambient Temperature Range-40°F - +140°F (-40°C - +60°C)
Max. altitude2000 m (6562 ft) with a max. input voltage of 1000 V / 3400 m (11155 ft) with a max. input voltage of 850 V
Certificates and compliance with standardsUL 1741-2010 Second Edition (incl. UL1741 Supplement SA 2016-09 for California Rule 21), UL1998 (for functions: AFCI, RCMU and isolation monitoring), IEEE 1547-2003, IEEE 1547a-2014, IEEE 1547.1-2003, ANSI/IEEE C62.41, FCC Part 15 A & B, NEC 2017 Article 690, C22. 2 No. 107.1-16, UL1699B Issue 2 -2013, CSA TIL M-07 Issue 1 -2013
DC connection technology6x DC+ and 6x DC- screw terminals for copper (solid / stranded / fine stranded) or aluminum (solid / stranded)
AC connection technologyScrew terminals 14-6 AWG
Protection Devices
DC reverse polarity protectionYes
Anti islandingInternal in accordance with UL 1741-2010, IEEE 1547-2003 and NEC
Over temperature protectionOutput power derating /Active cooling
AFCIYes
Rapid shutdown compliantYes
Ground fault protection with isolation monitor interrupterYes
DC disconnectorYes
Interfaces
Compatible Module Level ElectronicTigo TS4-F based on SunSpec PLC (pending testing)
Power Line Communication (PLC)Yes – SunSpec Rapid Shutdown communication standard
USB (type A socket)Datalogging and inverter update possible via USB
2x RS422 (RJ45 socket)Fronius Solar Net, interface protocol
Wi-Fi / Ethernet / Serial / Datalogger and webserverWireless standard 802.11 b/g/n / Fronius Solar.web, SunSpec Modbus TCP, JSON / SunSpec Modbus RTU
6 inputs and 4 digital I/OsLoad management signaling, multipurpose I/O
