Téléchargements
Produit
Increased System Reliability with New Fronius Cooling Liquid
The improved formula for Fronius Cooling Liquid offers increased corrosion protection and extended durability. Not only is this coolant biodegradable, but it can also be easily transported and stored because it is not subject to any labeling requirements or hazard classification.
Fronius Cooling Liquid and Change Kit
The improved formula for the new coolant not only increases system reliability but also prevents the build-up of bacteria in the cooling unit. In addition, Fronius Cooling Liquid offers reliable frost protection down to minus 20°C (-4°F). The increased corrosion protection means that the coolant also helps to prolong the service life of all metal components in the cooling unit, such as brass connections and torch components.
The high-performance coolant is used in all available Fronius cooling units and systems (TPS, TPS/i, MagicWave, and TransSteel). The green color prevents mix-ups. The Change Kit is used by users to change over to the new Cooling Liquid. The use of the new filter prevents damage that could be caused by contamination in the cooling circuit pump.
Propylene glycol forms the basis for the coolant. This chemical substance is classified as harmless, biodegradable, and environmentally friendly. Fronius is committed to using energy and resources sustainably and is constantly working to reduce environmental pollution. Fronius Cooling Liquid helps play a part in this.
