Installers & partners
Fronius Primo GEN24
Inverters for private photovoltaic systems with integrated basic backup power function
Our single-phase Fronius GEN24 inverter is the heart of private photovoltaic systems.
The Fronius GEN24 is equipped with PV Point, an integrated basic backup power function that supplies backup power to connected devices via a protected socket (as long as the sun is shining).
The Fronius Primo GEN24 boasts a wide range of features that support a sustainable, independent energy supply. Discover the key features for installers and their customers:
/ Active cooling technology for a longer service life
/ Flexible and fast installation
Product details
Input Data
Number of MPP trackers2
Max. input current (Idc max)
22 / 12 A
36 / 19 A
65 - 600 V
80 V
Nominal input voltage (Udc,r)
400 V
230 - 530 V
Usable MPP voltage range65 - 530 V
Number of DC connections2+2
7,5 kWpeak
Output Data
AC nominal output (Pac,r)
5000 W
Max. output power (Pac max)
5000 VA
Max. grid power demand5000 VA
Max. AC output current27,5 A
Grid connection (Uac,r)
1~ NPE 220/230 V
155 - 270 V
Frequency (fr)
50 / 60 Hz
Frequency range (fmin - fmax)
45 - 65 Hz
Power factor (cos φac,r)
0,8 - 1 ind./cap.
Back-up power1~NPE 220 V / 230 V
Nom. AC-Ausgangsstrom (220VAC)
22,7 A
Nom. AC-Ausgangsstrom (230VAC)
21,7 A
Output Data PV Point
Nom. output current (Iac max)
13 A
Grid connection1~NPE 220 V / 230 V
Max. switchover time PV-Point15 s
General Data
Width474 mm
Height530 mm
Depth165 mm
Weight15,38 kg
Weight incl. packaging19 kg
Protection classIP66
Protection class1
2 / 3
Night-time consumption< 10 W&amp;nbsp;&amp;nbsp;
CoolingActive Cooling
Ambient temperature range-40°C - +60°C
Permitted humidity0 - 100 %
Max. altitude 2)
4000 m
DC PV connection technology4x DC+ and 4x DC- push-in spring terminals 2.5 - 10 mm²
AC connection technology3 pole AC push-in spring terminals 2.5 - 10 mm²
3 pole backup power push-in spring terminals 1.5mm² - 10mm²
2x PE-screw terminals 2.5 - 16 mm² and  3x 2,5 - 10mm²
Certificates and compliance with standardsIEC 62109, IEC 62909, AS/NZS 4777.2, CEI 0-21, ABNT BNR 16149 und 16150, IEC 62116, IEC 61727, G98/G994)
Back-up power functionsPV Point
Sound emissions42 dB(A)
Interference emission classB
Efficiency
Max. efficiency (PV - grid)97,6 %
European efficiency (ηEU)96.3 / 97.2 / 96.7 (230Vdc / 400Vdc / 530Vdc)
η at 5% Pac,r 3)
87.3 / 91.3 / 89.2 (230Vdc / 400Vdc / 530Vdc)
η at 10% Pac,r 3)
92.2 / 94.8 / 93.6 (230Vdc / 400Vdc / 530Vdc)
η at 20% Pac,r 3)
95.3 / 96.7 / 96.1 (230Vdc / 400Vdc / 530Vdc)
η at 25% Pac,r 3)
95.9 / 97.0 / 96.6 (230Vdc / 400Vdc / 530Vdc)
η at 30% Pac,r 3)
96.2 / 97.2 / 96.8 (230Vdc / 400Vdc / 530Vdc)
η at 50% Pac,r 3)
96.8 / 97.5 / 97.2 (230Vdc / 400Vdc / 530Vdc)
η at 75% Pac,r 3)
96.9 / 97.5 / 97.3 (230Vdc / 400Vdc / 530Vdc)
η at 100% Pac,r 3)
MPP adaptation efficiency99.9
Protection Devices
DC insulation measurementYes
Overload behaviourOperating point shift. Power limitation
DC disconnectorYes
Interfaces
Emergency stop (WSD)Yes
2x RS485Modbus RTU SunSpec (third-party supplier) / Fronius Smart Meter, battery, Fronius Ohmpilot
Integrated data communication
SuperFlex Design
Dynamic Peak Manager
Multi Flow Technology
full backup
PV Point
Active Cooling
Fronius UP
Is a programme that allows the installer to upgrade a Fronius product via Solar.web – without any additional hardware. Fronius UP offers unique, new and innovative possibilities to expand Fronius products with new features according to the customers` needs at any time. This leads to maximum flexibility and future reliability.
The hybrid functions battery connection and full backup can be retrofitted to the GEN24 by Fronius UP.storage*!
Footnotes for technical data
1) According to IEC 62109-1. Option to retrofit surge protection device DC SPD type 1+2 for 2 MPP trackers available under the following item number: 4,240,313,CK
2) Unrestricted voltage range.
3) At Umpp min. / Udc,r / Umpp max.
4) You can find the current certificates under www.fronius.com/primo-gen24-plus-cert
