Installers & partners
Fronius Primo
The communicative inverter for optimised energy management.
With power categories ranging from 3.0 to 8.2 kW, the Fronius Primo perfectly complements the SnapINverter generation. This single-phase, transformerless device is the ideal inverter for private households. Its innovative SuperFlex Design provides maximum flexibility in system design, while the SnapINverter mounting system makes installation and maintenance as easy as possible. The communication package included as standard with WLAN, energy management, numerous interfaces, and much more besides, makes the Fronius Primo a communicative inverter for owner-occupiers.
Product details
Input Data
Number of MPP trackers2
Max. input current (Idc max)
18 / 18 A
36 / 36 A
80 - 1000 V
80 V
Nominal input voltage (Udc,r)
710 V
240 - 800 V
Usable MPP voltage range80 - 800 V
Number of DC connections2 + 2
9 kWpeak
Output Data
AC nominal output (Pac,r)
6000 W
Max. output power (Pac max)
6000 VA
AC output current (Iac nom)
26,1 A
Grid connection (Uac,r)
1~ NPE 220/230 V
180 - 270 V
Frequency (fr)
50 / 60 Hz
Frequency range (fmin - fmax)
45 - 65 Hz
Total harmonic distortion<3% @Pnom (230/400VAC 50Hz)
Power factor (cos φac,r)
0,85 - 1 ind./cap.
General Data
Dimension / width432,5 mm
Dimension / height642,5 mm
Dimension / depth205,5 mm
Weight21,07 kg
Weight incl. packaging25,8 kg
Degree of protectionIP 65
Protection class1
2 / 3
Night-time consumption< 1 W
CoolingRegulated air cooling
InstallationIndoors and outdoors
Ambient temperature range-40°C - +55°C
Permitted humidity0 - 100 %
Max. altitude 2)
4000 m
DC connection technology4x DC+ and 4x DC- screw terminals 2.5 - 16 mm²
AC connection technology3-pin AC screw terminals 2.5 - 16 mm²
Certificates and compliance with standardsDIN V VDE 0126-1-1/A1, IEC 62109-1/-2, IEC 62116, IEC 61727, AS 4777-2, AS 4777-3, G98/1, G99/1, CEI 0-21, VDE AR N 4105
Sound emissions55 dB(A)
Interference emission classB
Efficiency
Max. efficiency (PV - grid)98,1 %
European efficiency (ηEU)97,3 %
η at 5% Pac,r 3)
84,6 / 86,5 / 86,0 %
η at 10% Pac,r 3)
90,5 / 95,5 / 94,6 %
η at 20% Pac,r 3)
94,0 / 97,2 / 96,8 %
η at 25% Pac,r 3)
94,7 / 97,4 / 97,0 %
η at 30% Pac,r 3)
95,1 / 97,6 / 97,3 %
η at 50% Pac,r 3)
96,0 / 97,9 / 97,8 %
η at 75% Pac,r 3)
96,2 / 98,0 / 98,0 %
η at 100% Pac,r 3)
96,2 / 98,0 / 97,9 %
MPP adaptation efficiency> 99,9 %
Protection Devices
DC insulation measurementYes
Overload behaviourOperating point shift, power limitation
DC disconnectorYes
Interfaces
Wi-Fi / Ethernet LANFronius Solar.web, Modbus TCP SunSpec, Fronius Solar API (JSON)
6 inputs and 4 digital I/OsInterface to ripple control receiver
USB (type A socket) 4)
Data logging, inverter update via USB flash drive
2x RS422 (RJ45 socket) 4)
Fronius Solar Net
Signalling output 4)
Energy management (floating relay output)
Datalogger and web serverIntegrated
External input 4)
S0 meter connection / Evaluation of overvoltage protection
RS485Modbus RTU SunSpec or meter connection
SnapINverter technology
Integrated data communication
SuperFlex Design
Dynamic Peak Manager
Smart Grid Ready
Zero feed-in
Active Cooling
FOOTNOTES FOR TECHNICAL DATA
1) According to IEC 62109-1.
2) Unrestricted voltage range.
Further information
Fronius Primo 5.0-1, Fronius Primo 6.0-1 and Fronius Primo 8.2-1 are not fully compliant with VDE AR N 4105.
