Installers & partners
Fronius Verto
Your Photovoltaic System Can Do More
Fronius Verto, the adaptable inverter for small businesses, agricultural applications, and apartment buildings. Its flexibility makes it the perfect choice, both for constructing a new PV system and expanding an existing one. Featuring integrated safety features and innovative shade management, the Fronius Verto ensures optimum operation. Our flexible inverter facilitates energy sector integration thanks to its open interfaces. This means that it is easy to integrate charging stations such as Fronius Wattpilot and consumption regulators such as Fronius Ohmpilot.
Product details
Input Data
Number of MPP trackers4
150 V
Nominal input voltage (Udc,r)
600 V
Min. MPP voltage ( U mpp min)150 V
Max. MPP voltage ( U mpp max)870 V
45 kWpeak
Max. input current string (Idc max, String)
28 A
Output Data
AC nominal output (Pac,r)
30 kW
Max. output power (Pac max)
30 kVA
Max. grid power demand30 kVA
Max. AC output current53,7 A
Grid connection (Uac,r)
50
Grid connection (Uac,r)3~ (N)PE 380/220; 3~ (N)PE 400/230
60
Power factor range0-1 ind./cap.
General Data
Nominal voltage400/230V, 480/277V, 440/230V, 380/220V
Mains Frequency60 1/s, 50 1/sHz
Width574 mm
Height865 mm
Depth279 mm
Weight38,9 kg
Weight incl. packaging49,6 kg
Protection classIP66
Protection class1
Overvoltage category (DC / AC)2/3
Night-time consumption16W
Inverter designTrafolos
CoolingAktive Luftkühlung
InstallationInnen- und Außenmontage
Ambient temperature range-40°C - +60°C
Overvoltage protection 1)
Typ 1+2 oder Typ 2
Permitted humidity0 - 100%
Max. altitude 2)
4000 m
Sound emissions54,6 dB(A)
Efficiency
Max. efficiency97,47 %
European efficiency (ηEU)97,36 %
MPP adaptation efficiency> 99,9 %
Protection Devices
DC disconnectorIntegriert
Integral RCMUIntegriert
Interfaces
Ethernet LAN RJ4510/100Mbit; max. 100m Fronius Solar.web, Modbus TCP, JSON
6x digital in/out + 6x digital inAnbindung an Rundsteuerempfänger, Energiemanagement, Lastmanagement
Emergency stop (WSD)Integrated
Datalogger and web serverIntegriert
WLANFronius Solar.web, Modbus TCP, JSON, 802.11b/g
2x RS485Modbus RTU SunSpec (Drittanbieter) / Fronius Smart Meter
AC Connection Technology
Conductor materialAl und Cu
DC Connection Technology
Connection terminalsDC-Direktanschluss  Stäubli Multi Contact MC4
Technical Data
Cable glandAC: M32 (Ø12-24,5 mm)
Vorbereitet für
Option 1: M50 Kabelverschraubung (Ø10-35 mm)
Option 2: 1,5" Conduit Anschluss   PE & Datenkommunikation:
2 x M32 (3xØ4,9-5,5 mm + 3xØ6,7-8,5mm)
Grid connection(N)PE
Dynamic Peak Manager
Active Cooling
1) A single string is technically capable of processing the full / usable MPPT current. The maximum current per MPPT is limited to 28A.
2) Isc pv = Isc max ≥ Isc (STC) x 1.25 according to e.g: IEC 60364-7-712, NEC 2020, AS/NZS 5033:2021.
