Installers & partners
Fronius Primo GEN24 Plus
Inverter for private PV systems with PV Point or Full Backup
Our single-phase Fronius GEN24 Plus hybrid inverter is the ideal core for private PV systems. The Fronius GEN24 Plus offers an integrated basic backup power supply with PV Point and even a full backup power solution through the option of connecting a battery storage system.
The Fronius GEN24 Plus hybrid inverter enables energy self-sufficiency for electricity, heating, cooling and e-mobility with the use of a battery system. This means that the Fronius GEN24 Plus with Full Backup* has a backup power solutionthat even large consumers can use, such as heat pumps. What’s more, the Multi Flow Technology lets the hybrid inverter supply parallel energy flows in the system, even in backup power mode.
* Additional external components for grid switchover are required for the Full Backup. More information on this can be found in the operating instructions.
Product details
Input Data
Number of MPP trackers2
Max. input current (Idc max)
22 / 12 A
36 / 19 A
65 - 600 V
80 V
Nominal input voltage (Udc,r)
400 V
230 - 480 V
Usable MPP voltage range65 - 480 V
Number of DC connections2+2
Min. MPP voltage ( U mpp min)230 V
Max. MPP voltage ( U mpp max)480 V
9 kWpeak
Output Data
AC nominal output (Pac,r)
6000 W
Max. output power (Pac max)
6000 VA
Max. grid power demand6000 VA
Max. AC output current27,5 A
Grid connection (Uac,r)
1~ NPE 220/230 V
155 - 270 V
Frequency (fr)
50 / 60 Hz
Frequency range (fmin - fmax)
45 - 65 Hz
Power factor (cos φac,r)
0,8 - 1 ind./cap.
Back-up power1~NPE 220 V / 230 V
Nom. AC-Ausgangsstrom (220VAC)
27,3 A
Nom. AC-Ausgangsstrom (230VAC)
26,1 A
Output Data PV Point
Nom. output current (Iac max)
13 A
Grid connection1 ~ NPE 220 V / 230 V
Nominal operating frequency50 Hz / 60 Hz
Max. switchover time PV-Point15 s
Max. switchover time Full Backup10 s
Battery Connection
Number of DC connections1
Max. input current (Idc max.)
22 A
150 V - 455 V 7)
Max. input / output power (Depending on the connected battery)6200 W
Max. AC charging power (Depending on the connected battery)6000 W
Min. DC input voltage150 V
Max. DC input voltage455 V
General Data
Width474 mm
Height530 mm
Depth165 mm
Weight15,38 kg
Weight incl. packaging19 kg
Protection classIP66
Protection class1
2 / 3
Night-time consumption< 10 W
CoolingRegulated air cooling
Ambient temperature range-40°C - +60°C
Permitted humidity0 - 100 %
Max. altitude 2)
4000 m
DC PV connection technology4x DC+ and 4x DC- push-in spring terminals 2.5 - 10 mm²
DC battery connection technology1x BATT+ and 1x BATT- push-in spring terminals 2.5 - 10 mm²
AC connection technology3 pole AC push-in spring terminals 2.5 - 10 mm² 3 pole backup power push-in spring terminals 1.5mm² - 10mm² 2x PE-screw terminals 2.5 - 16 mm² and  3x 2,5 - 10mm²
Certificates and compliance with standardsIEC 62109, IEC 62909, AS/NZS 4777.2, CEI 0-21, ABNT BNR 16149 and 16150, IEC 62116, IEC 61727 8)
Back-up power functionsPV Point, full backup 4)
Compatible batteries 6)
BYD Battery-Box Premium HVS/HVM & LG RESU FLEX 5)
Sound emissions42 dB(A)
Interference emission classB
Efficiency
Max. efficiency (PV - grid)97,6 %
European efficiency (ηEU)96.1 / 97.1 / 96.7 (230Vdc / 400Vdc / 480Vdc)
η at 5% Pac,r 3)
88.4 / 92.1 / 90.2 (230Vdc / 400Vdc / 480Vdc)
η at 10% Pac,r 3)
93.3 / 95.5 / 94.6 (230Vdc / 400Vdc / 480Vdc)
η at 20% Pac,r 3)
95.8 / 97.0 / 96.5 (230Vdc / 400Vdc / 480Vdc)
η at 25% Pac,r 3)
96.2 / 97.2 / 96.8 (230Vdc / 400Vdc / 480Vdc)
η at 30% Pac,r 3)
96.5 / 97.4 / 97.0 (230Vdc / 400Vdc / 480Vdc)
η at 50% Pac,r 3)
96.8 / 97.5 / 97.3 (230Vdc / 400Vdc / 480Vdc)
η at 75% Pac,r 3)
η at 100% Pac,r 3)
96.7 / 97.4 / 97.1 (230Vdc / 400Vdc / 480Vdc)
MPP adaptation efficiency99.9
Protection Devices
DC insulation measurementYes
Overload behaviourOperating point shift. Power limitation
DC disconnectorYes
Interfaces
Emergency stop (WSD)Yes
2x RS485Modbus RTU SunSpec (third-party supplier) / Fronius Smart Meter, battery, Fronius Ohmpilot
Integrated data communication
SuperFlex Design
Dynamic Peak Manager
full backup
PV Point
Active Cooling
More information about the features of this product
FOOTNOTES FOR TECHNICAL DATA
1) According to IEC 62109-1. Option to retrofit surge protection device DC SPD type 1+2 for 2 MPP trackers available under the following item number: 4,240,313,CK
2) Unrestricted voltage range.
3) At Umpp min. / Udc,r / Umpp max.
4) Depending on the connected battery.
5) This does not apply to the BYD Battery-Box Premium HVS 10.2, HVS 12.8, HVM 8.3, HVM 22.1 & LG RESU FLEX 17.2
6) Depending on the country-specific certification and availability
7) An AC power derating of the inverter occurs from a battery DC input voltage of 419.7 V
8) You can find the current certificates under www.fronius.com/primo-gen24-plus-cert
