Installers & partners
Fronius Symo Advanced
Designed to rely on.
Further developed with safety in mind: the Fronius Symo Advanced opens the next chapter in the Fronius SnapINverter portfolio. The inverter combines proven performance with new safety technology, making the Fronius Symo Advanced the future-proof choice for commercial photovoltaic systems of all sizes. The latest generation of the inverter with power categories ranging from 10 to 20 kW impresses with reliable arc protection through the new Fronius Arc Guard technology, SuperFlex Design for absolute freedom in roof planning and maximum yields through the Dynamic Peak Manager.
Product details
Input Data
Number of MPP trackers2
Max. input current (Idc max)
27,0 / 16,5 A
55,7 / 34,0 A
200 - 1000 V
200 V
Nominal input voltage (Udc,r)
600 V
320 - 800 V
Usable MPP voltage range200 - 800
Number of DC connections3 + 3
18,8 kWpeak
Output Data
AC nominal output (Pac,r)
12,5 kW
Max. output power (Pac max)
12,5 kVA
AC output current (Iac nom)
18 A
Grid connection (Uac,r)
3~NPE 400/230, 3~NPE380/220 V
150 - 280 V
Frequency (fr)
50 / 60 Hz
Frequency range (fmin - fmax)
45 - 65 Hz
Total harmonic distortion<3% @Pnom (230/400VAC 50Hz)
Power factor (cos φac,r)
0 - 1 ind./cap.
General Data
Width510 mm
Height725 mm
Depth225 mm
Weight32 kg
Weight incl. packaging38,4 kg
Protection classIP 66
Protection class1
2 / 3
Night-time consumption<1W
CoolingRegulated air cooling
Ambient temperature range-25°C - +60°C
Permitted humidity0 - 100 %
Max. altitude 2)
2 000 m / 3 400 m
DC connection technology6x DC+ and 6x DC- screw terminals 2.5 - 16 mm²
AC connection technology5-pin AC screw terminals 2.5 - 16 mm²
Certificates and compliance with standardsIEC 62109-1/-2, IEC 62116, IEC 61727, VDE 0126-1-1/A1, VDE AR-N 4105, G98/1, G99/1, AS/NZS 4777.2, UNE 206007-1, CEI 0-21, CEI 0-16, NRS 097-2-1, TOR Erzeuger Typ A, EN 50549-1/-2, IEC 61683, IEC60068, IEC 63027:2023
Interference emission classB
Efficiency
Max. efficiency (PV - grid)97,8 %
European efficiency (ηEU)96.0 / 97.4 / 96.7%
η at 5% Pac,r 3)
90.6 / 93.0 / 89.6%
η at 10% Pac,r 3)
93.8 / 95.5 / 93.8%
η at 20% Pac,r 3)
95.5 / 97.1 / 96.0%
η at 25% Pac,r 3)
95.9 / 97.3 / 96.5%
η at 30% Pac,r 3)
96.2 / 97.5 / 96.8%
η at 50% Pac,r 3)
96.5 / 97.7 / 97.3%
η at 75% Pac,r 3)
96.4 / 97.8 / 97.4%
η at 100% Pac,r 3)
96.5 / 97.7 / 97.5%
MPP adaptation efficiency>99.9%
Protection Devices
DC insulation measurementYes
Overload behaviourOperating point shift. Power limitation
DC disconnectorYes
Arc fault circuit interrupter (Fronius Arc Guard)Yes
Interfaces
Wi-Fi / Ethernet LANFronius Solar.web, Modbus TCP SunSpec, Fronius Solar API (JSON)
6 inputs and 4 digital I/OsInterface to ripple control receiver, energy management
USB (type A socket) 4)
Data logging, inverter update via USB flash drive
2x RS422 (RJ45 socket) 4)
Fronius Solar Net
Signalling output 4)
Energy management (floating relay output)
External input 4)
S0 meter connection / Evaluation of overvoltage protection
RS485Modbus RTU SunSpec or meter connection
FOOTNOTES FOR TECHNICAL DATA
1) According to IEC 62109-1. DIN rail for optional type 1 + 2 or type 2 surge protection device available.
2) Unrestricted/restricted voltage range.
3) At Umpp min / Udc,r / Umpp max.
