Installers & partners
Fronius Symo
Maximum flexibility for the applications of tomorrow.
With power categories ranging from 3.0 to 8.2 kW, the transformerless Fronius Symo is the three-phase inverter for every system size. Owing to the SuperFlex Design, the Fronius Symo is the perfect answer to irregularly shaped or different roof orientations. A WLAN or Ethernet internet connection as standard plus easy integration of third-party components make the Fronius Symo one of the most communicative inverters on the market. Furthermore, the meter interface permits dynamic feed-in management and a clear visualisation of consumption.
Product details
Input Data
Number of MPP trackers2
Max. input current (Idc max)
16,0 / 16,0 A
31 / 31 A
150 - 1000 V
200 V
Nominal input voltage (Udc,r)
595 V
150 - 800 V
Usable MPP voltage range150 - 800 V
Number of DC connections2 + 2
9 kWpeak
Output Data
AC nominal output (Pac,r)
4500 W
Max. output power (Pac max)
4500 VA
AC output current (Iac nom)
6,5 A
Grid connection (Uac,r)
3~ NPE 400/230, 3~ NPE 380/220 V
150 - 280 V
Frequency (fr)
50 / 60 Hz
Frequency range (fmin - fmax)
45 - 65 Hz
Total harmonic distortion<3% @Pnom (230/400VAC 50Hz)
Power factor (cos φac,r)
0,85 - 1 ind./cap.
General Data
Dimension / width432,5 mm
Dimension / height642,5 mm
Dimension / depth205,5 mm
Weight19,75 kg
Weight incl. packaging23,05 kg
Degree of protectionIP 65
Protection class1
2 / 3
Night-time consumption< 1 W
CoolingRegulated air cooling
InstallationIndoors and outdoors
Ambient temperature range-25°C - +60°C
Permitted humidity0 - 100 %
Max. altitude 2)
2 000 m / 3 400 m
DC connection technology4x DC+ and 4x DC- screw terminals 2.5 - 16 mm² (16 mm² without ferrules)
AC connection technology5-pin AC screw terminals 2.5 - 16 mm² (16 mm² without ferrules)
Certificates and compliance with standardsÖVE / ÖNORM E 8001-4-712, DIN V VDE 0126-1-1/A1, VDE AR N 4105, IEC 62109-1/-2, IEC 62116, IEC 61727, AS 3100,
AS 4777-2, AS 4777-3, CER 06-190, G83/2, UNE 206007-1, SI 4777, CEI 0-21, NRS 097
Sound emissions52,6 dB(A)
Interference emission classB
Efficiency
Max. efficiency (PV - grid)98 %
European efficiency (ηEU)97,2 %
η at 5% Pac,r 3)
83,4 / 90,3 / 85,0 %
η at 10% Pac,r 3)
89,2 / 94,1 / 91,2 %
η at 20% Pac,r 3)
92,8 / 96,5 / 95,1 %
η at 25% Pac,r 3)
93,5 / 97,0 / 95,8 %
η at 30% Pac,r 3)
94,2 / 97,3 / 96,3 %
η at 50% Pac,r 3)
94,9 / 97,8 / 97,2 %
η at 75% Pac,r 3)
95,1 / 98,0 / 97,5 %
η at 100% Pac,r 3)
95,0 / 98,0 / 97,6 %
MPP adaptation efficiency> 99,9 %
Protection Devices
DC insulation measurementYes
Overload behaviourOperating point shift, power limitation
DC disconnectorYes
Interfaces
Wi-Fi / Ethernet LANFronius Solar.web, Modbus TCP SunSpec, Fronius Solar API (JSON)
6 inputs and 4 digital I/OsInterface to ripple control receiver
USB (type A socket) 4)
Data logging, inverter update via USB flash drive
2x RS422 (RJ45 socket) 4)
Fronius Solar Net
Signalling output 4)
Energy management (floating relay output)
Datalogger and web serverIntegrated string fuse holder
External input 4)
S0 meter connection / Evaluation of overvoltage protection
RS485Modbus RTU SunSpec or meter connection
SnapINverter technology
Integrated data communication
SuperFlex Design
Dynamic Peak Manager
Smart Grid Ready
Zero feed-in
Active Cooling
FOOTNOTES FOR TECHNICAL DATA
1) According to IEC 62109-1.
2) Unrestricted/restricted voltage range.
