Welducation Simulator The welder training of the future
Learning to weld made easy
Risk-free welding: Virtual training offers a safe, affordable, and resource-conserving way to realistically simulate complex welding processes. Those new to welding can repeat jobs as many times as necessary, improve their skills in a safe environment, and learn from their mistakes as a result. This is an ideal way of preparing trainees for real-life welding situations and lets them quickly and effectively respond to the constantly changing requirements of the job market and the industry.
Alongside the associated Welducation Campus platform, the Welducation Simulator offers trainees and trainers a complete teaching concept consisting of theoretical content and virtual training units with the simulator.
The advantages of the Welducation Simulator
Training and theory
The combination of theory and virtual training lets training participants consolidate their knowledge while also developing their practical skills. They can apply the concepts they have learned on the spot in the simulation, try out different welding techniques, and see the effects they have on the virtual workpiece.
More realistic than ever
Using AR technology, actual welding torches, and the housing of a real welding system creates a real-world welding simulation. Training participants also practice preparing for the actual welding process and the tasks between welding on the new simulator (checking the gas supply, attaching return lead cables, setting welding parameters, removing slag, etc.).
Safe and risk-free
The safety risk due to the hot arc, UV radiation, and welding fume is significantly higher for beginners during welding than in other professions. Virtual training completely eliminates this risk.
Cost-saving and sustainable
The Welducation Simulator enables resource-conserving training by saving expensive consumables such as materials for workpieces, wire, and shielding gas. In addition to protecting the environment, this also cuts costs.
Real components Actual welding torches, original connections, and the installation of the simulator in a standard welding system make the virtual welding simulation more realistic than ever.
3 process variants Trainees can use the Welducation Simulator to practice all three process variants (manual arc welding, MIG/MAG, and TIG). They do this while using various materials (steel, stainless steel, and aluminum), material thicknesses, and welding positions in the welding simulation.
Augmented reality Using AR glasses to integrate the real-life environment takes the welding simulation to a completely new level, giving the virtual welding situation an even more realistic look.
The same prep as for real welding The preparation stage prior to welding is also part of the training with the new Welducation Simulator. In addition to producing the perfect weld, users have to carry out checks ahead of time to ensure the ground earth connection has been established, the gas flow is regulated, and the correct welding parameters are set. The standard Fronius welding system interface is shown on the associated tablet so participants can already become familiar with handling welding systems during their training.
Digital training tool The Welducation Simulator is simple and easy to operate with the tablet included in the scope of supply. When using the cloud version, the Welducation Campus can be accessed both via the tablet and with other devices such as a mobile phone or laptop.
5
Real components
3 process variants
Augmented reality
5
Pipe connection
Lap joint
Butt weld
Corner weld
Butt weld
5
Pipe connection
Lap joint
Butt weld
Corner weld
5
Butt weld
Teaching concept
Virtual training
Training is completed without safety risks, with original welding torches and hosepacks, typical workpieces, and adjustable welding parameters. Creating the perfect weld is not the only focus. The tasks prior to, between, and after welding also need to be completed, just as they would in real life. Examples of these tasks include attaching the return lead cable, setting the correct welding parameters, and cleaning and touching up the weld.
Theory
The theoretical content on the Welducation Campus platform corresponds to a curriculum covering the latest methods. All results and learning progress are managed in this comprehensive training tool. In addition to the existing learning material, trainers have the option to create customized curricula and courses in order to adapt the training to the target group.
Step by step to a professional level
Extensive weld analysis options help training participants improve their technique and identify mistakes by letting them continually track their progress. Welding can be recorded and replayed at any time via the Welducation Campus, meaning the trainee’s own welding performance can be closely analyzed against the optimal target.
Three different levels of difficulty
Welding positions
Each welding task requires different techniques and manual skills, so learning different welding positions is an essential part of welding training.
Participants can train with a wide variety of workpieces, which they can attach in various positions on the stand included in the scope of supply. A large stand is also available to provide even more variation. Whether an overhead fillet weld or a single-V butt weld, participants can train on nearly any welding position.
Welducation Campus
Fast way of training skilled workers
The Welducation Simulator provides a fast way of training skilled workers by combining practical training units with theoretical content on the Welducation Campus platform.
This carefully designed training system takes the pressure off especially in times of skills shortages. Trainees can acquire knowledge and skills on their own with the help of theoretical content and prepared courses rather than requiring continual guidance from trainers.
The course overview on the Campus platform offers trainers a summary of trainees’ performance. They can see how many times the participants have practiced welding in the virtual space and whether the individual processes were successfully completed or not.
Helpful materials for trainers and trainees
Advantages of the Welducation Campus
By spurring one another on and interacting in this way, as well as being assessed professionally, trainees learn swiftly and effectively.
A pedagogically sophisticated evaluation system makes it possible to compare training results; this allows the trainees to be assessed objectively and transparently. A ranking list also motivates trainees to make the most of their welding potential.
The simulator’s HDMI connection makes it possible to display the simulation on external screens for training purposes.
The stand-alone version is included free of charge. It is an offline variant of the Welducation Campus that supports local work on the tablet.
The cloud license is subject to a fee and enables location-independent training. This license is available as a subscription for one, three, or five years.
Let´s get connected.
    1. APPLICABILITY
    2. PRICES AND PAYMENTS
    5. GENERAL EXPRESS WARRANTIES
    5.1 General. Seller warrants to Buyer only, subject to the disclaimers and limitations of the Agreement, that Goods to the extent manufactured by Seller shall be free from defects in materials and workmanship at the time of delivery which are discovered and reported to Seller within the period of 24 months from the delivery date. From the beginning of the 13th month of this period, however, Seller’s warranty shall be limited to making available, free of charge, the items needed for remedying the defects; from this time onwards, any warranty claims going beyond the above shall be inadmissible. This period limitation also applies to the supply of items deemed to be immovable and to work on items which are, or are deemed to be, immovable. The warranty period shall start to elapse upon the passage of risk. Buyer must always prove that defects coming to light during the warranty period were already present at the time of the passage of risk. This is not a warranty of performance, but a limited warranty as to the condition of the Goods at delivery. Seller does not warrant any portion of the Goods not designed, developed or manufactured by Seller (whether or not specified by Buyer), but Seller shall assign to Buyer upon request all assignable warranties of Seller’s suppliers related to such Goods. Because the Goods may be subject to a wide variety of use, installation, maintenance, cleaning, and other factors, the warranty is only against the named defects and not against any other defects or failures such as, but not limited to, those due to normal wear and tear, normal maintenance and unknown causes. Perishable and wear items are excluded from warranty against defects. Buyer shall ensure that all computer equipment and software included with or used with the Goods has adequate protection against viruses or other malicious software after initial installation. Seller’s warranty does not cover damage or contamination caused by such malicious software. Notwithstanding anything to the contrary, there is no warranty as to prototype Goods.
    6. PATENT WARRANTIES
    7.4 Warranty
    9.1 General Remedies. Defective or non-conforming Goods or parts thereof discovered and reported during the express warranty period shall be repaired, or replaced by Seller without any additional charge, and shipped to Buyer, FOB Seller’s plant, for reinstallation by Buyer at its cost, subject to the terms hereof of the Agreement, as Buyer’s exclusive remedy. The warranty obligation of Seller is limited to the repair or replacement at Seller’s plant of any part of the Goods which Buyer shall, within the warranty period, return to Seller, with transportation charges prepaid by Buyer, and which Seller shall determine upon examination to be defective or not in conformity with the express warranties contained herein. Goods cannot be deemed defective or non-conforming if Seller cannot duplicate the alleged failure. In lieu of repair or replacement, if Seller elects, Seller may, upon return of such Goods and making a determination of nonconformity or defect, keep the Goods and refund the purchase price as Buyer’s exclusive remedy. Seller may provide such repairs itself or through its third party contractors. Buyer’s remedies shall be limited (even in the event of Seller’s default of its warranty obligations or a failure of an item to meet its intended purpose) exclusively to those provided in this Section. UNDER NO CIRCUMSTANCES SHALL SELLER BE LIABLE, REGARDLESS AS TO WHETHER SELLER’S LIABILITY ARISES UNDER CONTRACT, TORT, STRICT LIABILITY STATUTES, OR OTHERWISE, FOR EXEMPLARY, PUNITIVE, SPECIAL, CONSEQUENTIAL OR INCIDENTAL DAMAGES, INCLUDING BUT NOT LIMITED TO: LOSS PROFITS OR REVENUES; INCREASED COSTS; DAMAGE TO EQUIPMENT, TOOLING,PREMISES, OR WORK-IN-PROCESS; COST OF CAPITAL; COST OF PURCHASED POWER; SUBSTITUTE OR ADDITIONAL EQUIPMENT, FACILITIES OR SERVICES; COST OF PRODUCTION INTERRUPTION OR START-UP; OR THE CLAIMS OF THIRD PARTIES FOR SUCH DAMAGES, WHETHER OR NOT THE DAMAGES WERE FORESEEABLE OR SELLER WAS ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. Each provision of the Agreement which provides for a limitation of liability, disclaimer of warranties, or exclusion or limitation of damages or remedy is severable and independent of each other and to be enforced as such. Buyer waives any causes of action or theories of liability relating to or arising under the Agreement including, but not limited to, those arising under contract, tort, strict liability, product liability statutes, or otherwise, except as specifically provided by the UCC as modified and limited herein. The replacement or repair of Goods by Seller does not give rise to any new or extended warranty, and the warranty period provided for herein shall not be extended by the length of any period from the date the defective or non-conforming Goods are received by Seller until the date the repaired or replacement Goods are delivered to Buyer or otherwise.
    10.1 SELLER DISCLAIMS ALL IMPLIED WARRANTIES AND SIMILAR OBLIGATIONS (OTHER THAN THAT THE GOODS WILL BE NEW AND GOOD TITLE) INCLUDING BUT NOT LIMITED TO THOSE OF NON-INFRINGEMENT, FITNESS FOR A PARTICULAR PURPOSE, AND MERCHANTABILITY, WHETHER OTHERWISE ARISING BY LAW, CUSTOM, USAGE, TRADE PRACTICE, COURSE OF DEALING, OR COURSE OF PERFORMANCE. There are no warranties which extend beyond those express warranties contained in the Agreement. Buyer affirms that it has not relied upon Seller’s skill nor judgment to select or furnish the Goods for any particular purpose beyond the specific express warranties in the Agreement. Any design provided by Seller is based on information provided by Buyer. Seller may rely entirely on information provided by Buyer and is under no obligation to verify such information or take any action to obtain explanatory or supplemental information from Buyer or third parties. Buyer’s approval of drawings and/or prototypes constitutes Buyer’s acceptance and waiver of any responsibility for a failure to consider or correct information or approval provided by Buyer. Any modifications of drawings, prototypes and other work of Seller after approval by Buyer shall be at Buyer’s expense at Seller’s normal rates for services and materials. Seller does not warrant the Goods will comply with the requirements of any safety or environmental code or regulation of any federal, state, municipality or other jurisdiction beyond the specific express warranties in the Agreement. Seller does not warrant that the Goods will operate with any accessories or within any system not sold under the Agreement and Seller’s warranty is limited to the operation of the Goods in a stand-alone mode, unless specifically stated in Seller’s written specifications. Some countries, states, or provinces do not allow the exclusion or limitation of implied warranties or the limitation of incidental or consequential damages for certain products supplied to consumers, or the limitation of liability for personal injury, so such limitations and exclusions may be limited in their application to an end user and others. When the implied warranties are not allowed to be excluded in their entirety, they will be limited to the duration of the applicable written warranty. The warranty gives specific legal rights which may vary depending on local law.
    11. INDEMNIFICATION
    12. SECURITY INTEREST
    12.1 In addition to any security interest granted by the UCC or other law, Buyer hereby grants a security interest to Seller in all Goods and documents related thereto and proceeds and products therefrom to secure all obligations of Buyer to Seller, whether or not arising under the Agreement. Seller may file a financing statement and at Seller’s request, Buyer shall sign financing statements and other documents, which evidence perfect and confirm the security interest. Buyer grants Seller an irrevocable power of attorney to sign Buyer’s name to a financing statement or other similar documents if necessary or convenient to perfect Seller’s security interest. Buyer shall not change the name of Buyer, the jurisdiction of Buyer’s formation, or the location of any Goods from the original delivery point or installation site without prior written notice to Seller. Buyer shall provide a lien waiver or subordination from all third parties to whom the Goods may be delivered. Buyer shall provide a landlord’s waiver or subordination of any lien rights at the premises to which the Goods are to be installed. In case of a default by Buyer, Seller may peaceably enter the premises of Buyer and others and take other actions to repossess or render inoperable all Goods in which it has a security interest provided that Seller provides Buyer with immediate notice it has rendered the Goods inoperable. In case of a default by Buyer, Buyer hereby irrevocably appoints Seller as its agent to obtain possession of the Goods and documents related thereto. Seller may install and activate procedures or devices to make the Goods or Software non-operative upon Buyer’s default. The Goods shall be and remain strictly personal property whether or not affixed or attached on permanent foundation or affixed or attached to building or structure. Title shall not transfer to Buyer until the Goods shall be paid in full. Buyer shall maintain the Goods which constitute inventory in a segregated area and not comingle any Goods which are not fully paid. Buyer shall not sell, exchange, transfer, convey, mortgage, pledge, hypothecate or grant a security interest in any Goods which are subject to the Agreement until payment has been made in full to Seller, at which time title shall transfer to Buyer. Buyer shall immediately advise Seller in writing of any damage to, change in location of, or seizure of, any of the Goods the price of which has not been paid to Seller.
    13. PROPRIETARY INFORMATION
    13.2 Seller’s Rights to Confidentiality. All proposals, plans and other information furnished by Seller in bidding, negotiating and performing the Agreement, are confidential and the property of Seller, whether or not marked “Confidential”, and shall not be shown or disclosed to any other bidder, and shall not be shown or disclosed to any other third party or used by buyer unless necessary for the selection or use of the Goods and notice of such disclosure has been given to Seller. Buyer shall treat as confidential any quotation or other business proposal from Seller and all technology which shall be made available, directly or indirectly to Buyer by Seller and by Seller’s licensors, including but not limited to drawings, schematics, specifications, bills of material, test results, analysis, recommendations, models, and designs, and Buyer shall use such proposal and technology only to evaluate its business relationship with Seller and to enable Buyer to perform under the Agreement. Buyer shall not manufacture or sell any product using confidential information provided by Seller or obtained from reverse engineering or decompiling Goods of Seller. Buyer shall not disclose, or authorize or instruct any third party to disclose, any confidential or proprietary information of Seller to any third party that is not bound by contract to at least the same duty of confidentiality to Seller as is Buyer. In addition, only those employees and contractors of Buyer having a need-to-know and bound by contract by the same confidentiality provisions as Buyer may be given access to such technology. Buyer shall maintain, for Seller’s inspection, written records which shall include the names and address of such employees and contractors granted such access. Buyer shall indemnify Seller from all expenses and damages related to the improper use or disclosure by Buyer or its employees and contractors. Business proposals and technology of Seller may be protected by patent, copyright, trademark and other law. No license or other right to business proposals or technology is granted to Buyer except as specifically provided in the Agreement.
    14. BREACH
    15.1 Disclaimer. BUYER AND THIRD PARTIES SHALL NOT BE ENTITLED TO ANY CONSEQUENTIAL, PUNITIVE, LIQUIDATED, EXEMPLARY OR INCIDENTAL DAMAGES, AS DEFINED IN THE APPLICABLE LAW OR OTHERWISE, EXCEPT AS TO ANY INDEMNIFICATION OBLIGATIONS TO THIRD PARTIES SPECIFICALLY PROVIDED IN THIS AGREEMENT. “CONSEQUENTIAL DAMAGES” SHALL INCLUDE, BUT NOT BE LIMITED TO, LOSS OF PROFITS OR REVENUE, LOSS OF USE OF CONTRACT GOODS, COSTS OF REPLACEMENT POWER OR CONTRACT GOODS, ADDITIONAL EXPENSES INCURRED IN THE USE OF CONTRACT GOODS OR FACILITIES, OR THE CLAIMS OF THIRD PARTIES, EVEN IF SELLER HAS BEEN ADVISED OF POSSIBILITY OF SUCH DAMAGES OR IF THEY ARE OTHERWISE REASONABLY FORESEEABLE. THIS DISCLAIMER SHALL APPLY TO INCIDENTAL, CONSEQUENTIAL AND LIQUIDATED DAMAGES BASED UPON ANY CAUSE OF ACTION WHATSOEVER ASSERTED AGAINST SELLER, INCLUDING ONE ARISING OUT OF PRINCIPLES OF CONTRACT, ANY BREACH OF WARRANTY, EXPRESSED OR IMPLIED, GUARANTEE, EQUIPMENT OR OTHER CONTRACT GOODS LIABILITY, NEGLIGENCE, TORT, OR ANY OTHER CAUSE PERTAINING TO PERFORMANCE OR NON-PERFORMANCE TO THE PROPOSAL OR ORDER BY SELLER. This limitation shall be enforced regardless of whether Seller has defaulted in its warranty or other obligations or the limited warranty is held to fail of its essential purpose. Any legal inability to limit or restrict the right of Buyer or a third party to such damages shall not affect the right of Seller to indemnification here-under, and under no circumstance shall Buyer recover more than the purchase price. 15.2 Overall Limitation. IRREGARDLESS OF THE DISCLAIMER IN SUBSECTION 15.1 ABOVE, UNDER NO CIRCUMSTANCES SHALL SELLER’S LIABILITY FOR CLAIMS FOR NON-DELIVERY OR OTHER NON-PERFORMANCE, DEFECTIVE PERFORMANCE, NON-CONFORMING GOODS, DEFECTIVE GOODS OR OTHERWISE EXCEED THE AMOUNT RECEIVED OR TO BE RECEIVED BY SELLER FOR THE PERFORMANCE OR SHIPMENT WHICH CONTAINED THE NON-CONFORMING GOODS, DEFECTIVE GOODS OR SUCH OTHER EVENT GIVING RISE TO THE CLAIM, EXCEPT AS MAY BE SPECIFICALLY PROVIDED BY THESE GENERAL TERMS.
    16. TERMINATION
    17. SEVERABILITY
    18. ASSIGNMENT
